Dear all, when making a pull request which introduce new schema changes to be applied to plugins, use the “schema plugin change” label https://github.com/geonetwork/core-geonetwork/labels/schema%20plugin%20change. This will make the life easier for those of you who are maintaining a schema plugin and we could track which changes are introduced in each release.
Cheers.
Francois
