[GeoNetwork-devel] Schema update
Hi!
Is there any guide online on how to update the schema folder. I am trying to update from version 3.0.0 to version 3.6.0 but I am facing errors regarding the schema and the viewMap which is probably related to the schema update issue.
Thanks in advance for your help.
Rene
(attachments)
Ren****é Agius
Software Developer - Software Reliability Engineering
Programme Management Department
MALTA INFORMATION TECHNOLOGY AGENCY
Email:
Office:
Mobile:
rene.agius@anonymised.com
+356 25992115
+356 79393044
Please read our Legal Notice: http://emailpolicy.mita.gov.mt
Kindly consider your environmental responsibility before printing this e-mail
Hi Rene
Unfortunately not that I’m aware, recently the pull requests that affect the schemas got a label to indicate that there’re relevant changes to apply in schemas, but this is quite recent.
A change done since 3.4.3 is about requiring to indicate the min/max versions of GeoNetwork supported, you need to add in schema-ident.xml of your schema an entry like the following, but is not the only change since 3.0.x as also there’re changes in templates used in xslt files:
https://github.com/geonetwork/core-geonetwork/blob/master/schemas/iso19139/src/main/plugin/iso19139/schema-ident.xml#L31
What error(s) do you get?
Jose García
On Thu, Apr 4, 2019 at 10:34 AM Agius Rene at MITA <rene.agius@anonymised.com> wrote:
Hi!
Rene
Ren****é Agius
Email:
Office:
Mobile:
+356 25992115
+356 79393044
GeoNetwork-devel mailing list
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
