I'd like to know if someone had problem with simple search, just set up the
drop down list with regions.
In my geonetwork it doesn't work.
Thx,
Clara
View this message in context: http://n2.nabble.com/Serch-by-regions-doesn-t-work-tp4287020p4287020.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Now, I've set "Geographic bounding box".
Do I set another value into metadata?
Clara
View this message in context: http://n2.nabble.com/Serch-by-regions-doesn-t-work-tp4287020p4290370.html
Hi!
I understood the problem.
I do research on very small regions, with latitude and longitude less than
one degree.
For some reason the GeoNetwork not do research on regions less than one
degree.
Does anyone know how and where can I fix it?
Thank you very much,
Clara
View this message in context: http://n2.nabble.com/Serch-by-regions-doesn-t-work-tp4287020p4332419.html
Hello Clara,
you can find where to configure these 1 degree parameter for the geographical search at
\geonetwork\web\geonetwork\xml\search\lucene-utils.xsl
Víctor
Víctor Centella Fuster
Prodevelop, Integración de tecnologías
http://www.prodevelop.es
Servei d'Informàtica
Conselleria de Medi Ambient, Aigua, Urbanisme i Habitatge
Francesc Cubells 7, 46011 València
Tel.: 96 197 3942
Email: asistenciagis1_ctv@anonymised.com
http://www.cma.gva.es
----- Original Message ----- From: "clarush" <cfagnola@anonymised.com>
To: <geonetwork-devel@lists.sourceforge.net>
Sent: Wednesday, January 13, 2010 9:56 AM
Subject: Re: [GeoNetwork-devel] Serch by regions doesn't work
Hi!
one degree.
degree.
Clara
Sent from the GeoNetwork developer mailing list archive at Nabble.com.------------------------------------------------------------------------------
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
GeoNetwork-devel mailing list
Thanks Victor!
Removing the (+/-) 1 works
But serves to make research less accurate?
See you!
Clara
View this message in context: http://n2.nabble.com/Serch-by-regions-doesn-t-work-tp4287020p4349533.html
