[Geonetwork-devel] some tweaking issues
Well i've started to frist to translate the geonetwork to portuguese which I can after all chages give to the dev group...but I'm having some difficulty changing some files to portuguese with the accents!This all so happens in intermap here i can't change it because of the "~,´,`" chars, any help would be appreciated,cause i'm not really a programmer!
Another issue is how to remove some buttons, like the validate button on the edit metadata page, when i remove it in the metadata-validate.xls (I think ist this one) the all page breaksdown, and it shows a transformation error I think!Any help here would be appreciated also!
The last issue is with the link to a WMS, to the getmap url!I do the address of the geoserver (which i use) intermap always return "could not perform the following request"!I follow a message on the users mailing list but it also return the same message!Any help would be appreciated.
Thank you for your time and any help in advance!
Best Regards
Hugo Santos
Hi Hugo,
Some stuff inline below.
On 9 Jan 2006, at 11:24, hdsantos@anonymised.com wrote:
This is probably related to the use of an editor that does not use/support UTF8. The language files should use UTF8 encoding.
The template that creates the validate button is defined in the metadata-edit.xsl file. You will have to comment out the block on lines 200-203 .
The linkage field should contain the URL to the server
The protocol to OpenGISMap Service
The name to the layer name of the layer you want to display
The description is optional
You could first try to just point to the capabilities file:
Linkage is again the URL to the server
The protocol is OpenGIS Capabilities
The name and description to whatever
This should open the full list of layers available from the map server in InterMap. Let us know if that works. Otherwise you may be able to provide more feedback by supplying log files showing the output from InterMap.
Good luck,
Jeroen
Best Regards
Hugo Santos
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files
for problems? Stop! Download the new AJAX search engine that makes
searching your log files as easy as surfing the web. DOWNLOAD SPLUNK!
http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click
Geonetwork-devel mailing list
Geonetwork-devel@lists.sourceforge.net
