GeoNetwork PSC:
I also rounded up some details from java 11 compatibility testing last week (thanks to David for the initial research).
I understand there was work on Spring upgrade and JPA upgrade, how did that go?
Jody Garnett
GeoNetwork PSC:
Jody Garnett
That is good news, updating the page to check that as done.
I believe that a good percentage of the split-package issues identified are a result of our war not being strictly defined.
As an example both jrt:/java.xml.ws, javaee-api-7.0.jar both define javax.jws package, I expect it is a mistake that this is included. Marking items like this that we expect to be provided by jetty or tomcat as scope “provided” will ensure they are available when compiling, but not bundled in our war lib folder to cause split-package problems.
On Tue, Jul 14, 2020 at 11:23 PM Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jody
The work for Spring upgrade and JPA upgrade is already merged in the 4.0.x branch.
Jose GarcíaOn Tue, Jul 14, 2020 at 5:29 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
GeoNetwork PSC:
Jody Garnett
GeoNetwork-devel mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork–
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664Please consider the environment before printing this email.
I had a first pass at reviewing the dependencies with an evaluation of update, replace, ignore judgement call.
As an example many of the jai-core warnings do not prevent startup and can be ignored.
I have some questions on that page:
ant-1.6.5.jar
hadoop-core-1.0.0.jar
scala-library-2.9.1.jar
I do not believe we can make substantial progress on this activity until war is fixed (currently contains multiple competing xml apis):
Jody Garnett
Hi Jody
See inline.
Jose García
ant-1.6.5.jar
- why do we have a build tool included in the war?
- what is hadoop used for? this is a distributed computing library right …
This is used in activemq-core 5.6.0 dependency in the messaging module, that is used to index WFS features in ElasticSearch, but not very clear for what is used the JMS messaging. Florent or Francois can provide more details.
- what do we use scala for? scala does not show up as any of the languages used in the repository analytics …
This is used by the activemq-core 5.6.0 dependency also.
split package: javax.xml.parsers [jrt:/java.xml, xml-apis-1.4.01.jar, xmlParserAPIs-2.6.2.jar
split package: javax.xml.transform.dom [jrt:/java.xml, xml-apis-1.4.01.jar, xmlParserAPIs-2.6.2.jar]
xmlParserAPIs-2.6.2.jar seem containing a subset of the content xml-apis-1.4.01.jar
From the dependency tree:
commons-digester 1.6 → xml-apis-1.4.01.jar
xom 1.1 ->xmlParserAPIs-2.6.2.jar, xom is a direct dependency in some modules, but also transitive dependency for esapi 2.1.0
Not very clear the usage of xom, we need to check the code to verify for what is used and if can’t be avoided, probably check if can excluded xmlParserAPIs-2.6.2.jar as seem a subset of the content xml-apis-1.4.01.jar
Le lun. 20 juil. 2020 à 09:14, Jose Garcia <jose.garcia@anonymised.com> a écrit :
Hi Jody
See inline.
Jose GarcíaOn Sat, Jul 18, 2020 at 2:17 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
ant-1.6.5.jar
When creating WFS features harvester, one idea was to be able to separate this app to the main one. Based on Camel, the harvester could be launched as CLI or run as a webapp. JMS is used to trigger harvesting tasks and is one option for communication between apps in the microservices move we discussed.
Cheers.
Francois
split package: javax.xml.transform.dom [jrt:/java.xml, xml-apis-1.4.01.jar, xmlParserAPIs-2.6.2.jar]xmlParserAPIs-2.6.2.jar seem containing a subset of the content xml-apis-1.4.01.jar
Jody GarnettOn Wed, 15 Jul 2020 at 09:05, Jody Garnett <jody.garnett@anonymised.com> wrote:
Hi Jody
GeoNetwork PSC:
Jody Garnett
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
