[GeoNetwork-devel] sprint results: maven build improvements part 2/2
GeoNetwork PSC:
The next proposal requires your input, it contains a proposal to resolve some of the complexity in the web-app pom.xml and should result in an easier/faster build process for everyone.
I would like confirmation on the approach before sinking time into implementation :slight_smile:
Please check out the proposal here:
Jody Garnett
Thanks to Juan for a quick review.
Proposal has been updated to stage sql migration scripts into a distinct target/migrate folder (I was unaware that geonetwork requires these on the filesystem).
Jody Garnett
On Tue, 14 Jul 2020 at 08:04, Jody Garnett <jody.garnett@anonymised.com> wrote:
GeoNetwork PSC:
Jody Garnett
Hi Jody
Thanks for the proposal. It looks good to me, any improvement on the build is welcome. Some comments:
1) In this workflow web-ui resources, and schema plugins folders would be used directly, no process-resources required.
Note that currently the schematron validation files (sch) files get compiled into xslt in the schema plugins folder that is copied to **web** during **process-resources** in GeoNetwork startup. With this change will be created in the schema sources folder, I guess could be solved adding in .gitignore some rule to exclude xslt files from the **schematron** folders.
2) Related to the discussion items:
- However there is a duplication of effort, and there may be some frustration testing the war bundle as a result.
I think it can be relevant to elaborate this a bit more in the proposal, so it’s clear about the duplication of effort.
- Q: The gn database is created in the current directory, can this move to target folder?
A: The only reason to keep in sources can be to avoid loosing the info with mvn clean, but maybe then can be configured a profile to externalize the data directory?
I guess as you pointed out in the proposal, if it can be configured to create it in an external directory using a maven profile, sounds a good option.
Jose García
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Thanks Jose that is helpful.
Some comments inline:
That is … odd. I wonder why it is not producing xslt files in this location already (must be an accident or undocument side effect of having so much duplication in the current build).
I am not sure I can untangle this until we are doing the work, your suggestion of using .gitignore is fine, but I would prefer not to have src folders being modified at runtime if we can avoid it. We would also need to avoid copying these generated files into target/schemas when staging content for war.
Does GeoNetwork only compile these files on startup? Or does it watch for changes …
I am trying to say that using jetty:run does not exactly test the same thing using jetty:run-war.
To use your schematron example:
  1. If you were using jetty:run and process-resources to try out a rule change
  2. And then packaged a war for a customer
  3. You would of missed out including your rule change in the war
To fix:
  1. Use install to package the plugin jar and zip
  2. And then package war for customer (it will pick up the rule change which is now included in the zip)
I hope this example makes it more clear? Two ways of doing things is duplication.
Yes I proposed a web/data_directory to make this more clear (and provide a single location to .gitignore)
Jose García
On Tue, Jul 14, 2020 at 5:27 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Tue, 14 Jul 2020 at 08:04, Jody Garnett <jody.garnett@anonymised.com…> wrote:
GeoNetwork PSC:
Jody Garnett
GeoNetwork-devel mailing list
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi
See inline.
Doesn’t watch the files for changes, but can trigger a service to re-create them.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
