Hi!
I run a Geodata catalog that I want to have as open as possible.
All data should be searchable and downloadable w/o login (Guest). So I put all records in All and Guest.
This has been no problem in GN3 but GN4 changed something.
Here are two urls passed from GN4(0.4-SNAPSHOT) from the same metadata record. The first one does not work, the second one does. The action is "Add layer to map’.
GET http://maps3.sgu.se/geoserver/ows?request=GetCapabilities&SERVICE=WMS
The first one does not work. Error 500 is returned. As you see, a proxy statement is injected, and the link is url encoded (unnecessary)
What may be the reason for this? I have no proxy, and proxy is off in the settings.
If it is by design I would like to be able to switch it off.
Regards, Mats.E
GisKraft, Geodatakonsult
Mats Elfström, Marsvinsholms stationsväg 80, 271 93 Ystad, Sweden
tel: +46 70 595 39 35 / www.giskraft.se
Hi Mats, I also noticed the sendError exception on Tomcat last week which needs to be fixed.
On Jetty, the error is more explicit
See https://github.com/geonetwork/core-geonetwork/pull/4712
So you have 2 options:
- In the admin, trigger the link analysis which will populates the link table that the proxy is using to allow or not access.
- turn off proxy check
HTH
Francois
Le ven. 30 avr. 2021 à 14:47, Mats Elfström <mats.elfstrom@anonymised.com> a écrit :
Hi!
Regards, Mats.E
GeoNetwork-devel mailing list
Hi Francois!
Thank you for that hint and the github thread.
I would like to say that the error message and error code should be revised. An error 500 (Internal Server Error) was not helpful. Not until I began tapping the internet connection I found the proxy problem.
I have explored the options you gave.
1/ Analyse links: This had the desired effect, but has to be triggered manually after each harvest. it is also a time consuming process. My current database contains some 10000 links.
2/ Change the parameter in web.xml to
securityMode
NONE</param-val
DO NOT DO THIS!
It froze the entire instance which went into some arrest and ejected hundreds of catalina springwork errors. I had to restart Tomcat with some difficulty and consider myself lucky to be able to get it running again.
CONCLUSION: As I am scheduling all harvesters for a weekly run, I will have to remember to manually start a link analysis after each harvest batch.
Regards, Mats.E
Hi
Le mar. 4 mai 2021 à 15:17, Mats Elfström <mats.elfstrom@anonymised.com.1330…> a écrit :
Hi Francois!
Errors are quite explicit on Jetty (see screenshot in the PR) but on Tomcat there is an issue when sending the errors back to the client …
securityMode
NONE</param-val
DO NOT DO THIS!
What type of errors ?
This can probably be improved to have a background task taking care of this.
Francois
Regards, Mats.E
Den fre 30 apr. 2021 kl 15:24 skrev Francois Prunayre <fx.prunayre@anonymised.com>:
HTH
Francois
Hi!
Regards, Mats.E
Hi Francois!
Basically, what seems to have happened is that the shift from DB_LINK_CHECK to NONE triggered an unexpected database migration attempt.
As I have almost 10000 metadata records, this brought the machine to a standstill. And soon it ran out of memory. I have 8GB RAM on that machine.
Here are the first few log lines after the web.xml edit.
/Regards, Mats.E
2021-05-04 14:30:33,383 INFO [geonetwork.databasemigration] - - Migration …
2021-05-04 14:30:33,523 INFO [geonetwork.databasemigration] - Webapp version:4.0.4-SNAPSHOT subversion:SNAPSHOT
2021-05-04 14:30:33,523 INFO [geonetwork.databasemigration] - Database version:4.0.4 subversion:SNAPSHOT
2021-05-04 14:30:33,523 INFO [geonetwork.databasemigration] - Application version equals the Database version, no migration task to apply.
2021-05-04 14:30:51,431 ERROR [jeeves] - JeevesContextLoaderListener: Error creating bean with name ‘org.fao.geonet.camelPeriodicProducer.MessageProducerFactory#0’: Invocation of init method failed; nested exception is org.quartz.SchedulerException: Unable to register scheduler with MBeanServer. [See nested exception: javax.management.InstanceAlreadyExistsException: quartz:type=QuartzScheduler,name=DefaultQuartzScheduler-harvest-wfs,instance=NON_CLUSTERED]
org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘org.fao.geonet.camelPeriodicProducer.MessageProducerFactory#0’: Invocation of init method failed; nested exception is org.quartz.SchedulerException: Unable to register scheduler with MBeanServer. [See nested exception: javax.management.InstanceAlreadyExistsException: quartz:type=QuartzScheduler,name=DefaultQuartzScheduler-harvest-wfs,instance=NON_CLUSTERED]
Hi Mats, this error “Unable to register scheduler with MBeanServer” does not sound related to the proxy config. I also observed it yesterday on a setup with 6 GeoNetwork in the same Jetty. Some of them are failing to start on
https://github.com/geonetwork/core-geonetwork/blob/main/workers/camelPeriodicProducer/src/main/java/org/fao/geonet/camelPeriodicProducer/MessageProducerFactory.java#L47
Trying to figure out why.
Francois
Le mar. 4 mai 2021 à 16:57, Mats Elfström <mats.elfstrom@anonymised.com> a écrit :
Hi Francois!
/Regards, Mats.E
Den tis 4 maj 2021 kl 16:17 skrev Francois Prunayre <fx.prunayre@anonymised.com>:
Hi
Le mar. 4 mai 2021 à 15:17, Mats Elfström <mats.elfstrom@anonymised.com> a écrit :
Hi Francois!
securityMode
NONE</param-val
DO NOT DO THIS!
Francois
Regards, Mats.E
HTH
Francois
Hi!
Regards, Mats.E
