Hello,
I am setting up some harvesting regimes for WxS services. In the
configuration there is an option to select a Target Schema. But the only
option here that I can make available is ISO19139. I store my metadata in
different profiles of ISO 19139 and would like this harvested metadata to
match. These profiles are already loaded as plugin schemas. How do I make
these available in the "Target Schema" dropdown in the OGCWxS harvesting
configuration? What is the procedure, in a nutshell, for adding additional
Target Schemas?
Byron
View this message in context: http://osgeo-org.1560.n6.nabble.com/Target-Schema-for-OGCWxS-Harvesting-in-GN2-8-x-tp5016117.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
