I have a suggestion
http://host/geonetwork/srv/en/xml.info?type=site
could contain a timestamp when metadata was last updated.
Then it is easy for another component to check if newer metadata has arrived.
Or can this be found elsewhere?
kind regards
Jørn-Vegard Røsnes
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
I found an alternative way
first
http://host/geonetwork/srv/en/xml.search?sortBy=changeDate&from=1&to=20
then based on latest changeDate
http://host/geonetwork/srv/en/xml.search?dateFrom=2012-04-19T11:43:20&sortBy=changeDate
kind regards
Jørn-Vegard Røsnes
----- Original Message -----
To: geonetwork-devel@lists.sourceforge.net
Sent: Thursday, 19 April, 2012 1:19:04 PM
Subject: [GeoNetwork-devel] timestamp for metadata last updated
I have a suggestion
arrived.
kind regards
Jørn-Vegard Røsnes
CONFIDENTIALITY
may be
only meant
or use is
received in
sender
properly.
For Developers, A Lot Can Happen In A Second.
Boundary is the first to Know...and Tell You.
Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
http://p.sf.net/sfu/Boundary-d2dvs2
GeoNetwork-devel mailing list
CONFIDENTIALITY
properly.
