On Wed, Apr 26, 2017 at 8:48 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
Seem the no support of the pipe in the url is due to a fix for a security issue, seem related to this: https://bugzilla.redhat.com/show_bug.cgi?id=1397484
I see 2 options, in the Angular code:
- Encode in the request the pipe to %7C
- Change the request to use a comma instead of a pipe
I’ll check to commit a fix with one of these options.
Jose García
On Wed, Apr 26, 2017 at 8:30 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
I need to try it in tomcat 8, will check during today.
Maybe we can define other separator in the service to avoid the issue. Seem the service accepts also a comma, seem was changed to use a pipe due to Angular UI using that, but I guess that can be changed.
Jose García
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
On Tue, Apr 25, 2017 at 6:59 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi Jose, Developers,
I have just had the opportunity to try adding the URIEncoding element to tomcat8’s server.xml and I can report that it makes no difference to the display (or not) of associated records in geonetwork 3.0. Is there another fix for this?
Thanks
Jo
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
Register here: https://www.eventbrite.co.uk/e/astun-user-conference-2017-tickets-31457635635?aff=es2
Astun User Conference web page: https://astuntechnology.com/astun-user-conference/
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
Helpdesk and customer portal
Company registration no. 5410695. Registered in England and Wales. Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
On Wed, Mar 29, 2017 at 4:10 PM, Jo Cook <jocook@anonymised.com1036…> wrote:
Hi Jose,
I don’t have any statements about URIEncoding in server.xml but will add that in and see if it makes any difference.
Thanks
Jo
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
On Fri, Mar 24, 2017 at 12:45 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
I don’t know the reason for that change. In 3.2.x the service has change and should be used the end-point /api/records/UUID/related like:
https://SERVER/geonetwork/srv/api/records/UUID/related?type=parent&type=children&type=services&type=datasets
At least in the UI seem sending the values separated.
Not sure if will solve your case, but have you check if Tomcat has the URI encoding to UTF-8, I got some issues with accents, etc. if not set.
Although the pipe character should not cause that … take look in server.xml to the Connector:
<``Connector` `port``=``"8080"` `maxHttpHeaderSize``=``"8192"` maxThreads=“150” minSpareThreads=“25” maxSpareThreads=“75” ```enableLookups``=``"false" redirectPort``=``"8443" acceptCount``=``"100"
connectionTimeout``=``"20000"` `disableUploadTimeout``=``"true"` URIEncoding=“UTF-8” ```/>
And make sure that has the URIEncoding=“UTF-8” attribute.
Jose García
Jo Cook
On Fri, Mar 17, 2017 at 12:15 PM, Jo Cook <jocook@anonymised.com.> wrote:
Hi Developers,
I’ve not had a response to my question about pipes in query parameters causing an issue with tomcat8, so I’ve dug a little deeper on my own and this commit seems to be the culprit: https://github.com/geonetwork/core-geonetwork/commit/1695e14d7a606f073021c32195a9fcbfe89b56cd. It looks to me as if this is only a problem with geonetwork 3.0.x and not with 3.2.x and later. Can someone confirm this for me? If so, could I revert this line: https://github.com/geonetwork/core-geonetwork/blob/3.0.5/services/src/main/java/org/fao/geonet/guiservices/metadata/GetRelated.java#L322 so that it uses commas rather than pipes, which seems to be what it did before that commit?
I’m happy to submit an issue for this, but I don’t have enough understanding of whether the fix has implications elsewhere in the code, or even if it’s going to allow my associated resources to display, given the comment with that commit about angularjs using pipes rather than commas.
Can someone give me some advice here please?
Thanks
Jo
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.comorge.net
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
On Mon, Mar 13, 2017 at 1:34 PM, Jo Cook <jocook@anonymised.com> wrote:
I think I’ve hit an issue with Geonetwork 3.0.5 where requests with | in the query parameters fail on tomcat8 because of the behaviour described in this stack exchange post: http://stackoverflow.com/questions/41053653/tomcat-8-is-not-able-to-handle-get-request-with-in-query-parameters
The particular issue I’m seeing is that associated records don’t display in default view, the debug console in the browser shows that the following sorts of request https://URL/geonetwork/srv/eng/md.relations?_content_type=json&uuid=UUID&type=parent|children|service|dataset return a 400 error with no errors in the geonetwork log files. If the | are substituted for , then the request works.
I’m using tomcat 8.0.32.0, by the way.
Is this something that should be submitted as a github issue for 3.0.x, eg to use a different separator, and/or is it fixed in 3.2.x? Is there a patch I can do to on current install since it’s a production instance and I might not have the option to try multiple different tomcat versions to see which triggers the bug and which does not?
Many thanks
Jo
Jo Cook
Jo Cook
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
