Hi list,
when batch editing records the parameters passed to updateMetadata function make it not to run update-fixed-info and also to not update the gmd:dateStamp element [1]:
boolean validate = false;
boolean ufo = false;
boolean index = true;
dataMan.updateMetadata(
serviceContext, record.getId() + "", metadata,
validate, ufo, index,
"eng", // Not used when validate is false
changeDate, false);
Is there any reason for not running update-fixed-info here and for not updating the last modified date inside the document?
[1] https://github.com/geonetwork/core-geonetwork/blob/master/services/src/main/java/org/fao/geonet/api/records/editing/BatchEditsApi.java#L204-L213
Vriendelijke groeten / Kind regards,
Juan Luis Rodríguez.
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Hi Juan,
Not sure for UFO but sometime users don’t want to update the dateStamp - eg. when fixing typo.
So we can add a parameter for this ?
For the dateStamp, I would put a default to false as you can use the API to update it if you really want. But if you prefer true, that’s fine too. (Similar discussion here https://github.com/geonetwork/core-geonetwork/pull/3747)
For UFO, it really makes sense to run it when changing CharacterString and multilingual records, gml elements so maybe can always be applied ? or at least by default true ?
Francois
Le mer. 17 avr. 2019 à 10:38, Juan Luis Rodríguez Ponce <juanluisrp@anonymised.com> a écrit :
Hi list,
changeDate, false);
Veenderweg 13
6721 WD Bennekom
The Netherlands
Hi Francois,
Hi Juan,
The thing is that update timestamp requires updateFixedInfo to be true since is that XSLT the one that changes the gmd:dateStamp.
if (ufo) {
metadataXml = updateFixedInfo(schema, Optional.of(intId), uuid, metadataXml, parentUuid,
(updateDateStamp ? UpdateDatestamp.YES : UpdateDatestamp.NO), context);
I could set the ufo to be always true and update the datetamp based on a parameter received by the API.
Veenderweg 13
6721 WD Bennekom
The Netherlands
