[GeoNetwork-devel] User defined symbology
hello
i’m working on an implementation of geonetwork that renders wms layers to the map - once a few have been rendered (taking their colour from the wms service) it becomes harder to differentiate them (although layer opacity can be changed) - one possible solution might be to allow users to set layer colours.
from initial observations, it looks as it this might need to take place at the point that openlayers renders to canvas, any ideas or recommendations?
joe
https://maplondon.ml/
GREATER LONDON AUTHORITY NOTICE:
The information in this email may contain confidential or privileged materials. For more information see https://www.london.gov.uk/about-us/email-notice/
Depending how you want to implement, in general the point of WMS is that the data provider is providing a predrawn layer that is intended to be used as is.
  • A WMS can be setup with multiple named styles, and a user interface can be used to choose between these if available
  • Depending on the WMS service it may allow you to pass inline SLD with the requested fill color. In this case your web application is taking over, but the rendering is still going to occur on the server side
  • You may be able to play with some special effects on the images once they are available in openlayers as individual ImageLayer layers.
  • I assume this tutorial https://openlayers.org/en/latest/examples/color-manipulation.html is simiilar to what you would like to achieve?
  • One technique I enjoyed when working on a desktop client was to use opacity to fade out every layer execpet the currently selected layer. If you are providing a legend you could turn this into a hover effect as the mouse passes over each legend entry.
Jody Garnett
interesting, the hue adjustment in the openlayers demo you provided should work well for differentiation purposes, also i think it will look neat sitting alongside the opacity slider in the gn ui - thanks!
  • the use case here is a planner assessing a given location and pulling in all the various planning restriction zones (polygons) that cover that location.
Sent: 21 August 2020 07:32
To: Joseph Leach Joseph.Leach@anonymised.com
Cc: geonetwork-devel@lists.sourceforge.net geonetwork-devel@anonymised.coms.sourceforge.net
Subject: Re: [GeoNetwork-devel] User defined symbology
Jody Garnett
On Thu, 20 Aug 2020 at 10:13, Joseph Leach <Joseph.Leach@anonymised.com…> wrote:
hello
joe
GeoNetwork-devel mailing list
This message has been scanned for viruses by the Greater London Authority.
Click here to report this email as spam.
oh, the legend hover idea is nice too, it would also work on first press for touch interfaces
cheers again
Sent: 21 August 2020 11:15
To: Jody Garnett jody.garnett@anonymised.com
Jody Garnett
On Thu, 20 Aug 2020 at 10:13, Joseph Leach <Joseph.Leach@anonymised.com05…> wrote:
hello
joe
