I am successfully using WMS services with both the Map Viewer (via
mapservers.xml) and with the Online Resource (interactive map link).
I would like to also add ArcIMS image and feature services in the same
manner. When I add an ArcIMS image service to mapservers.xml, e.g.,
<server type="1" name="ArcIMS GeneralInfo">
<url>http://myservername/servlet/com.esri.esrimap.Esrimap?ServiceName=GeneralInfo</url>
</server>
restart GN, and then click on the "Add more layers..." button below the Map
Viewer, the "ArcIMS Generalinfo" service shows up in the list, but when I
click on the arrow in front of it, I get the message, "The requested
operation could not be performed"
In the console, I see:
MAPSERVER ---> 14
URL --->
TYPE ---> 1
Force refreshCache ---> false
This error is probably the reason I am not able to get the Online Resource
link to work.
If anyone has a working example of using ArcIMS image and feature services
with GN I'd really appreciate the assistance.
Thanks, Bob
View this message in context: http://n2.nabble.com/Using-ArcIMS-image-services-in-mapservers.xml-and-Online-Resource-tp2397763p2397763.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
Hi Bob,
The native ArcIMS support is not working in version 2.1+ AFAIK. Even though it shouldn't be hard to fix this, it definitely needs some work. Feature services won't work in the current map viewer.
Ciao,
Jeroen
On Feb 27, 2009, at 8:48 PM, Bob Nutsch wrote:
</server>
MAPSERVER ---> 14
URL --->
TYPE ---> 1
link to work.
Thanks, Bob
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
GeoNetwork-devel mailing list
