[GeoNetwork-devel] Using repo.osgeo.org mirror when building 2.10 to replace core-maven-repo
GitHub now supports maven (and other package repository structures directly) and has sent us an email asking that we avoid using https://github.com/geonetwork/core-maven-repo/ as a maven repository. One thing about advertising a maven repository is we have no direct control over how it is used by external parties.
Juan was kind enough to ensure all the contents are now uploaded to repo.osgeo.org. I have prepared a pull request (https://github.com/geonetwork/core-maven-repo/pull/4) to make the change.
The pull request README.md documents what is needed:
  • Historic use with 2.10.x builds will continue to work without change (2.10.x uses this repo as a submodule pointing to a specific revision)
  • Historic use with 3.0.x builds will continue to work without change. This branch already requires maven environment ~/.m2/settings.xml customization to redirect to repo.osgeo.org - an additional mirror redirection is required.
Jody Garnett
Buenos días, por favor su ayuda, tengo un problema con Geonetwork 3.12 cuando hago un harvesting de un servicio WMS o WFS.
* Solo importa 1 registro o metadato y el resto presentan el siguiente error:
Good morning, please help, I have a problem with Geonetwork 3.12 when I harvest a WMS or WFS service.
* It only imports 1 record or metadata and the rest present the following error:
2021-08-23T16:00:59,141-0500 INFO  [wfs_regional] - Starting harvesting of wfs_servicio
2021-08-23T16:00:59,159-0500 INFO  [wfs_regional] - Started harvesting from node : wfs_servicio (OgcWxSHarvester)
2021-08-23T16:00:59,162-0500 INFO  [wfs_regional] - Retrieving remote metadata information for : wfs_servicio
2021-08-23T16:00:59,412-0500 INFO  [wfs_regional] -   - Number of layers, featureTypes, Coverages or process found : **55**
2021-08-23T16:00:59,412-0500 INFO  [wfs_regional] -   - <b>Loading layer: srv:aeropuerto with UUID dbaf2fcbbe6a5cd02a883f60e29eb5fba4a1c05a (hash of capabilities URL + layer name).
2021-08-23T16:00:59,434-0500 WARN  [wfs_regional] -   - Failed to load metadata document for layer 'srv:aeropuerto'. Error is: 'For input string: ""',</b>
El mar, 10 ago 2021 a las 17:52, Jody Garnett via GeoNetwork-devel (<geonetwork-devel@lists.sourceforge.net>) escribió:
Jody Garnett
GeoNetwork-devel mailing list
