[GeoNetwork-devel] Versioning
Hi All,
I’m struggling to get anywhere with versioning in Geonetwork 3.2.3, with postgresql as the back-end database. I’m not sure if my issue is with configuration or something else- happy to help debug if someone can give me some pointers.
If I enable versioning on a record when editing, nothing happens as far as I can tell. If I make a change to the record, and save it, the change is saved. However if I go back to editing it, and check the versioning button, then it still says “start versioning”. I see no options for checking the history.
In the log files, I can see the following, which looks applicable:
org.springframework.transaction.NoTransactionException: No transaction aspect-managed TransactionStatus in scope
at org.springframework.transaction.interceptor.TransactionAspectSupport.currentTransactionStatus(TransactionAspectSupport.java:122)
at org.fao.geonet.kernel.SvnManager.setHistory(SvnManager.java:349)
at org.fao.geonet.kernel.XmlSerializerSvn.update(XmlSerializerSvn.java:100)
at org.fao.geonet.kernel.DataManager.updateMetadata(DataManager.java:1816)
at org.fao.geonet.api.records.editing.EditUtils.updateContent(EditUtils.java:182)
at org.fao.geonet.api.records.editing.AjaxEditUtils.updateContent(AjaxEditUtils.java:55)
at org.fao.geonet.api.records.editing.MetadataEditingApi.saveEdits(MetadataEditingApi.java:287)
at org.fao.geonet.api.records.editing.MetadataEditingApi$$FastClassBySpringCGLIB$$363e745.invoke()
at org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
at org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:720)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
at org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:64)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:655)
at org.fao.geonet.api.records.editing.MetadataEditingApi$$EnhancerBySpringCGLIB$$d6499272.saveEdits()
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:222)
at org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:137)
at org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:814)
at org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:737)
at org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at jeeves.config.springutil.JeevesDispatcherServlet.access$001(JeevesDispatcherServlet.java:41)
at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:54)
at jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:51)
at jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:73)
at jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:48)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:969)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:871)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:845)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1689)
at org.fao.geonet.web.CORSResponseFilter.doFilter(CORSResponseFilter.java:128)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676)
at org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:121)
at org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:58)
at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)
at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)
at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)
at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:381)
at org.geonetwork.http.SessionTimeoutCookieFilter.doFilter(SessionTimeoutCookieFilter.java:89)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:118)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:84)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:342)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:103)
at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:113)
at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:45)
at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:199)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:50)
at jeeves.config.springutil.MultiNodeAuthenticationFilter.doFilter(MultiNodeAuthenticationFilter.java:125)
at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:110)
at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:105)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:192)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:160)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:104)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1668)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1174)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1106)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:213)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:119)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:524)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:319)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:253)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)
at java.lang.Thread.run(Thread.java:748)
I’ve tried this on both a single node installation and a multi-node installation, with the same errors both times.
Any pointers?
Thanks
Jo
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
Hi Jo
I have tested with 3.2.2 and 3.4.x and same issue, but at least in 3.2.2 I don’t see any error trace, the service seem returning the metadata id:
http://localhost:8080/geonetwork/srv/eng/md.versioning.start?id=17074
  1. 17074
But nothing changes in the UI, checking the UI code seem there’s no logic that indicates the label gets updated or disabled when the versioning is enabled.
The main problem for this feature is that you need to use a SVN client to access the versioned data, no way to do that in the current UI, but you can try in the data directory to open the metadata_subversion folder with SVN client and check if the metadata you versioned ended there.
In any case, please open a issue, I guess at least the UI should be updated if the metadata is versioned (also doesn’t seem to be any method that retrieves this information, but just from a quick look).
Jose García
On Wed, Oct 4, 2017 at 3:22 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi All,
Any pointers?
Thanks
Jo
Jo Cook
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
Helpdesk and customer portal
Company registration no. 5410695. Registered in England and Wales. Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
GeoNetwork-devel mailing list
GeoNetwork-devel@…537…sourceforge.net
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Hi Jose,
Thanks for this. I have checked with svn command line tools and as far as I can tell, versioning is happening, but it’s not showing in the interface. So I’ve submitted a bug for it.
Jo
On Wed, Oct 11, 2017 at 8:03 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
  1. 17074
Jose García
Hi All,
Any pointers?
Thanks
Jo
Jo Cook
GeoNetwork-devel@anonymised.comorge.net
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jo Cook
