[GeoNetwork-devel] Web client for searching metadata of geonetwork
Hi, I want to develope a web client for searching metadata of geonetwork.
The main page its a simple form with some fields (similar to the advanced search of geonetwork, title, abstract,bbox).
I would like to know the possibilities to do this, and if I need to use some tecnology (java,php,soap) or I can use only static pages (html,js).
Thanks
Hi Francisco,
The easiest solution I think is doing a RSS search and then parse the
GeoRSS feed (XML) that you get back.
Example:
http://localhost:8080/geonetwork/srv/en/rss.search?any=[yoursearchkeyword]
http://bluenet.its.utas.edu.au/geonetwork/srv/en/rss.search?title=[yoursearchkeyword]
I don't know what other fields can be used, but I would assume that you
can use the form field names as the parameters in your URL.
Does that help?
Cheers, Roald
geonetwork.
(html,js).
Thanks
Roald de Wit
Software Engineer
roald.dewit@anonymised.com
Commercial Support for Open Source GIS Software
http://lisasoft.com/LISAsoft/SupportedProducts/
Hi Francisco,
I think you have many solutions for that using : XML services (xml.search, xml.metadata.get …), RSS search as mentionned by Roald, or CS-W protocol.
Depends on your needs and what you want to achieve with metadata you retrieved in your interface.
Feel free to ask for more details if needed,
HTH,
Mathieu
On Wed, Dec 17, 2008 at 1:29 PM, Francisco Arrebola Pascual <ricken11@anonymised.com> wrote:
Thanks
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can’t happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/
GeoNetwork-devel mailing list
Mathieu Coudert
mcoudert@anonymised.com
Hi, thanks a lot for this information.
I will explain my problem.
I have a page with some textboxes like: title, abstract, keywords, category, dealer, contact…and the coordinates for a extent search too. (very similar to the advanced search of geonetwork, but I want a separated service)
I think the best option is to use CSW protocol, because allow me to do more advanced queries.
I know that exists a lot of ways to implemet CSW protocol, but I need to integrate my proyect in a PHP CMS.
In this point, the best way to implement CSW in PHP is using SOAP, or there are other options?
Thanks again
2008/12/19 Mathieu Coudert <mcoudert@anonymised.com>
Hi Francisco,
HTH,
Mathieu
Thanks
Mathieu Coudert
Un día te encontré y al otro te perdí
Indeed! However, CSW is still in progress and proposals to improved it will be deliver in few weeks.
You do not need to implement CSW, you just have to send it requests using GET/POST/SOAP, and deal with the CSW answer to display your results in your interface. So maybe you will have to deal with XML answers in PHP or javascript as well.
Mathieu
Thanks Mathieu,
Could we study this 3 posiblities GET/POST/SOAP?
Which is the best for a GetRecords request?
I think that GET request is the easiest but is limited.
Is it posible to specify a query like this at the “constraint” parameter?:
------- title like ‘%europe spain%’ AND abstract like ‘%rivers%’ AND bbox = “minx,miny,maxx,maxy” …
Mathieu
Hi Francisco,
Francisco wrote:
Thanks Mathieu,
in geocat.ch sandbox we have a CSW JS client using Get or Post method.
GET/POST/SOAP will be the same. But some CSW operation could be only available in some of them. For example, Transaction operation in CSW are only available via POST/SOAP.
Is it posible to specify a query like this at the "constraint" parameter?:
------- title like '%europe spain%' AND abstract like '%rivers%' AND bbox = "minx,miny,maxx,maxy" ........
Take care with CQL as CQL parser is not so nice for now in 2.2.0 (cf.
http://www.nabble.com/Is-it-me-or-is-the-CSW-common-query-language-just-wrong-in-2.2.0---SEC%3DUNCLASSIFIED--td18864856.html#a19855027 ). We are currently migrating to GeoTools CQL parser.
With 2.2.0, using Filter encoding is probably better.
HTH.
Francois
2008/12/19 Mathieu Coudert <mcoudert@anonymised.com <mailto:mcoudert@anonymised.com>>
        keywords, category, dealer, contact...and the coordinates for a
    Mathieu
