[GeoNetwork-devel] web-itests all passing
Just wanted notify other Geonetwork developers that the geonetwork integration tests all pass now for both 2.8.x and master.
I have both branches running on an integration server and running all the tests so I will forward messages if/when the tests fail.
If you want to run them yourselves here is the incantation:
mvn install -Pitests
The build + tests take about 10 minutes on my integration machine
There are about 350 integration tests and 160 junit tests.
that gets us above 500 tests now.
The integration tests focus on searching at the moment but I will keep adding more over time.
Super Jesse!! Thanks!
Jeroen
On 24 jan. 2013, at 12:46, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only -- learn more at:
http://p.sf.net/sfu/learnnow-d2d_______________________________________________
GeoNetwork-devel mailing list
Dear Jeroen and GeoNetwork’s Developers,
Here in FAO there is the need to get some information on GeoNetwork releases plan.
Is it possible to get an approximate date for next release 2.8? And then, is there a chance to see the feature described in the ticket 377 (http://trac.osgeo.org/geonetwork/ticket/377) implemented on it?
Thank you,
Patrizia
Sent: 24 January 2013 12:46
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] web-itests all passing
