[GeoNetwork-devel] web-ui-docs errors while compiling
--- Treść przekazanej wiadomości ---
Temat: web-ui-docs errors while compiling
Data: Mon, 09 Feb 2015 14:20:42 +0100
Nadawca: Marek Marczak <mmarczak@anonymised.com>
Adresat: geonetwork-users@lists.sourceforge.net
Hello everybody,
I'm trying to build Geonetwork from sources under Windows 7, but
compiling stops at web-ui-docs step:
[INFO]
[INFO] Building JS API and Service documentation 2.11.0-SNAPSHOT
[INFO]
[INFO]
[INFO] --- gmaven-plugin:1.0:execute (Check memory settings) @
web-ui-docs ---
[INFO]
         Max Heap Memory: 3072.0 MB
         Max PermGen Size: 3072.0 MB
[INFO]
[INFO] --- frontend-maven-plugin:0.0.11:install-node-and-npm (install
node and n
pm) @ web-ui-docs ---
[INFO] Installing node version v0.10.24
[INFO] No proxy was configured, downloading directly
[INFO] Installed node.exe locally.
[INFO] Found NPM version 1.3.23
[INFO]
[INFO] --- frontend-maven-plugin:0.0.11:npm (npm download modules) @
web-ui-docs
[INFO] Running 'npm install --color=false' in
C:\Users\3R-wirt-win7\Desktop\geon
etwork - Kopia\web-ui-docs
[INFO] Nazwa pliku, nazwa katalogu lub sk?adnia etykiety woluminu jest
niepopraw
na.
[INFO]
[INFO] Reactor Summary:
[INFO]
[INFO] GeoNetwork opensource .............................. SUCCESS [
11.682 s]
[INFO] common utils ....................................... SUCCESS
[01:06 min]
[INFO] Caching xslt module ................................ SUCCESS [
42.785 s]
[INFO] GeoNetwork domain .................................. SUCCESS
[02:06 min]
[INFO] Jeeves modules ..................................... SUCCESS
[01:57 min]
[INFO] ArcSDE module (dummy-api) .......................... SUCCESS [
0.726 s]
[INFO] GeoNetwork user interface module ................... SUCCESS [
6.700 s]
[INFO] JS API and Service documentation ................... FAILURE
[02:49 min]
[INFO] Oaipmh modules ..................................... SKIPPED
[INFO] GeoNetwork web client module ....................... SKIPPED
[INFO] GeoNetwork core .................................... SKIPPED
[INFO] GeoNetwork CSW server .............................. SKIPPED
[INFO] GeoNetwork health monitor .......................... SKIPPED
[INFO] GeoNetwork harvesters .............................. SKIPPED
[INFO] GeoNetwork services ................................ SKIPPED
[INFO] Geonetwork Web Resources 4 Java .................... SKIPPED
[INFO] GeoNetwork Web module .............................. SKIPPED
[INFO] GeoNetwork E2E Javascript Tests .................... SKIPPED
[INFO]
[INFO] BUILD FAILURE
[INFO]
[INFO] Total time: 09:05 min
[INFO] Finished at: 2015-02-09T14:06:11+01:00
[INFO] Final Memory: 68M/475M
[INFO]
[ERROR] Failed to execute goal
com.github.eirslett:frontend-maven-plugin:0.0.11:
npm (npm download modules) on project web-ui-docs: 'npm install
--color=false' f
ailed. (error code 1) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the
-e swit
ch.
[ERROR]
[ERROR] For more information about the errors and possible solutions,
please rea
d the following articles:
[ERROR] [Help 1]
http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureExc
eption
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the
command
[ERROR] mvn <goals> -rf :web-ui-docs
Any ideas?
Best regards!
Could you try it again in a directory without a space in the path? Also re-run it with -X to get the full trace.
Jesse
On Mon, Feb 9, 2015 at 2:25 PM, Marek Marczak <mmarczak@anonymised.com> wrote:
— Treść przekazanej wiadomości —
Temat:
Data:
Nadawca:
Adresat:
Hello everybody,
[INFO]
[INFO]
[INFO]
web-ui-docs ---
[INFO]
[INFO]
node and n
[INFO]
web-ui-docs
niepopraw
na.
[INFO]
[INFO]
11.682 s]
[01:06 min]
42.785 s]
[02:06 min]
[01:57 min]
0.726 s]
6.700 s]
[02:49 min]
[INFO]
[INFO]
[INFO]
--color=false' f
[ERROR]
-e swit
ch.
[ERROR]
please rea
[ERROR] [Help 1]
[http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureExc](http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureExc)
eption
[ERROR]
command
Any ideas?
Best regards!
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
GeoNetwork-devel mailing list
