I have GeoNetwork deployed as a docker container, and I would like to add the ISO Harmonized North American Profile (HNAP) plugin.
Also, how would I go about disabling the French language for it? I do recall Jody telling me about using HNAP and that I can disable the French language stuff.
I am currently running GeoNetwork v4.4.6.0
tac
November 5, 2025, 12:15am
2
With ChatGPT help, I created a Dockerfile to load the three files:
FROM geonetwork:4.4.8
Switch to root (default in most base images)
USER root
Elegantly create the jetty group and user if they do not exist
RUN getent group jetty || groupadd -r jetty &&
id -u jetty || useradd -r -g jetty jetty
Copy files, set ownership to jetty, set permissions
COPY ./hnap8/gn-schema-iso19139.ca.HNAP-4.4.8-0.jar /opt/geonetwork/WEB-INF/lib/schema-iso19139.ca.HNAP-4.4.8-0.jar
RUN chown jetty:jetty /opt/geonetwork/WEB-INF/lib/schema-iso19139.ca.HNAP-4.4.8-0.jar
RUN chmod 664 /opt/geonetwork/WEB-INF/lib/schema-iso19139.ca.HNAP-4.4.8-0.jar
COPY ./hnap8/iso19139.ca.HNAP /opt/geonetwork/WEB-INF/data/config/schema_plugins/iso19139.ca.HNAP
RUN chown -R jetty:jetty /opt/geonetwork/WEB-INF/data/config/schema_plugins/iso19139.ca.HNAP
RUN chmod -R 775 /opt/geonetwork/WEB-INF/data/config/schema_plugins/iso19139.ca.HNAP
COPY ./hnap8/doc /opt/geonetwork/doc
RUN chown -R jetty:jetty /opt/geonetwork/doc
RUN chmod -R 775 /opt/geonetwork/doc
Switch back to jetty user
USER jetty
