Hello, since today two GeoNetwork applications won’t start and are giving me a raised exception error. I am using GeoNetwork 3.12.11 with Tomcat9 on a Windows server.
I get the following error on both pages:
Message
Failed parsing schedule at info from settings: null
Handler
org.fao.geonet.Geonetwork
Exception
java.lang.IllegalArgumentException: Failed parsing schedule at info from settings: null
Stack
at org.fao.geonet.kernel.setting.SettingInfo.getLuceneIndexOptimizerSchedulerAt(SettingInfo.java:168)
at org.fao.geonet.kernel.search.LuceneOptimizerManager.(LuceneOptimizerManager.java:69)
at org.fao.geonet.kernel.search.SearchManager.initNonStaticData(SearchManager.java:511)
at org.fao.geonet.kernel.search.SearchManager.init(SearchManager.java:488)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:299)
at org.fao.geonet.Geonetwork.start(Geonetwork.java:117)
at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:457)
at jeeves.server.JeevesEngine.init(JeevesEngine.java:193)
at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:80)
at javax.servlet.GenericServlet.init(GenericServlet.java:143)
at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper.java:1106)
at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1063)
at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:960)
at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4673)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4980)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:662)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1023)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1910)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:112)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:824)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:474)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1617)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:318)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:898)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:795)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1332)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1322)
at java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:134)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:871)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:249)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:428)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:914)
at org.apache.catalina.startup.Catalina.start(Catalina.java:772)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:347)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:478)
If you need logs, please let me know how i can share them. Do i just post them within this topic? Thank you in advance.
I have already tried deleting the data folder but that didn’t work.
