(I think you will get better response to your questions when you give some context to your use of GN and send/sign your emails with your real name.)
I am working on the same topics: having installed GN 2.6.0 and trying to configure the map/extent viewers. Out of the box a lot of stuff already works, but if you need a more specific configuration you need to (currently) modify XML and XSLT files. See below.
On 06-10-10 20:11, silst wrote:
is it possible to access a geowebcache ( the last release) ?
Yes ! In config-gui.xml you can add <layer>s and thus GWC layers.
(The built-in GeoServer is handy but not neccessarily the only map source)
How can we send to the map Object the hash table resolutions for
alignement with the grid cache .
Currently IMO not through standard configuration parameters in config-gui.xml. I have modified xsl/main-page.xsl to configure resolutions within the generated Javascript. Look for "var mapOptions" (3x) in that file and modify these. Maybe you can add layer options in config-gui.xml (see below).
Is there any parameters in config-gui that implements this function ?
See above. I would say: not yet.
When i add a layer by the overlays tree when searching a server, how can
i give to this layer the hash table resolutions ?
I.s.o. modifying main-page.xsl you may try to set resolutions in <layer> elements within "options" in config-gui.xml.
As said I am in the middle of trying to have alternative projections/resolutions/extents, so any suggestions from others welcomed.
best,
--Just
Just van den Broecke
The Netherlands
http://www.justobjects.nl
we are using in test geonetwork 2.6.0
Thank you
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2& L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today.
http://p.sf.net/sfu/beautyoftheweb
GeoNetwork-users mailing list
