[GeoNetwork-users] API: Expected CSRF token not found. Has your session expired?
I am returning back to the GN after some time and found some interesting
tools like API.
I would like to POST XML file via API. I have followed the example on
Swagger and I am able to get the token and the authorization is confirmed.
curl -X POST -H "X-XSRF-TOKEN: $TOKEN" --user $CATALOGUSER:$CATALOGPASS -b
/tmp/cookie "$CATALOG/srv/eng/info?type=me"
<info>
  <me authenticated="true">
    <profile>Administrator</profile>
    <username>admin</username>
    <id>1</id>
    <name>admin</name>
    <surname>admin</surname>
    <email></email>
    <organisation />
    <hash>c65870a7a1de222423a624b1a73e4da7</hash>
  </me>
  <env>
    <baseURL>/geonetwork</baseURL>
    <node>srv</node>
  </env>
</info>
When I try to upload metadata from XML file:
curl -X POST
"$CATALOG/srv/api/0.1/records?metadataType=METADATA&uuidProcessing=NOTHING&rejectIfInvalid=false&publishToAll=false&assignToCatalog=false&transformWith=_none_"
-H "accept: application/json" -H "Content-Type: application/json" -H
"X-XSRF-TOKEN: $TOKEN" -d @sample.xml
I got an error that as I understand the GN does not know about the token or
does not know that the token has been associated with the logged user.
Message: Expected CSRF token not found. Has your session expired?
I have tried a lot of things, but nothing worked for me.
This is a fresh copy of GN 3.10.6.
Any help appreciated
Jan Růžička, Ph.D.
freelancer, researcher and volontaire
Geoinformatics
tel: +420 775 032 091
e-mail: jan.ruzicka.vsb@anonymised.com <http://jan.ruzicka.vsb.cz/&gt;
http://github.com/ruz76/
http://gismentors.eu/
http://dolnilhota.info/
http://1jcbo.cz/
Hi Jan,
probably you are missing the cookie in your request. Check the example at
https://www.geonetwork-opensource.org/manuals/trunk/en/api/the-geonetwork-api.html#using-the-api-to-apply-an-xsl-process
Your second request should be
curl -X POST
"X-XSRF-TOKEN: $TOKEN" -d @sample.xml -b /tmp/cookie
On Wed, Mar 17, 2021 at 1:51 PM Jan Růžička <jan.ruzicka.vsb@anonymised.com>
wrote:
tools like API.
<info>
    <id>1</id>
    <name>admin</name>
    <email></email>
    <organisation />
  </me>
  <env>
    <node>srv</node>
  </env>
</info>
curl -X POST
Jan Růžička, Ph.D.
Geoinformatics
http://1jcbo.cz/
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Juan Luis Rodríguez.
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
It seems you need -c parameter too:
curl -X POST \
-H "accept: application/json" -H "Content-Type: application/json" \
-H "X-XSRF-TOKEN: $TOKEN" -d @sample.xml -c /tmp/cookie -b /tmp/cookie
On Thu, Mar 25, 2021 at 9:03 AM Juan Luis Rodríguez Ponce <
juanluisrp@anonymised.com> wrote:
Hi Jan,
curl -X POST
wrote:
tools like API.
<info>
    <id>1</id>
    <name>admin</name>
    <email></email>
    <organisation />
  </me>
  <env>
    <node>srv</node>
  </env>
</info>
curl -X POST
or
Jan Růžička, Ph.D.
Geoinformatics
http://1jcbo.cz/
this email.*
this email.*
