I'm trying to check the new functionality of harvesting metadata from....well, through ArcSDE. Does anyone knows where to put the jsde9x.jar?
- Testing GeoNetwork 2.4.0 RC0 using McKoi/Jetty -
Thanks to all,
Walter
Thanks to all,
Walter
Under the /web/geonetwork/WEB-INF/lib directory I guess.
HTH,
Mathieu
On Wed, May 6, 2009 at 6:24 PM, <walter.simonazzi@anonymised.com> wrote:
- Testing GeoNetwork 2.4.0 RC0 using McKoi/Jetty -Thanks to all,
Walter
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK
i700
Series Scanner you'll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
GeoNetwork-users mailing list
hi,
I wrote the ArcSDE harvesting function, using 4 jars that are proprietary
software by ESRI. That's why they are not committed to Geonetwork SVN.
They are :
concurrent.jar
icu4j_3_2.jar
jpe_sdk.jar
jsde_sdk.jar
I don't know if all 4 are really necessary but of course I have not
decompiled them, so couldn't tell you. Also I don't know how they relate to
your jsde9x.jar.
They must be in, or under, /web/geonetwork/WEB-INF/lib, indeed, as Mathieu
told you. I'd say try putting your jar there and let us know how it goes..
kind regards
Heikki Doeleman
On Thu, May 7, 2009 at 10:22 AM, Mathieu Coudert <
mathieu.coudert@anonymised.com> wrote:
HTH,Mathieu
> Hi all,
jsde9x.jar?
> Thanks to all,
> Walter
to
> i700
i700
Thanks to both. I placed these four jars in \lib, so now I can do the
connection to ArcSDE / 9.3, and this is what I get:
Connect to ArcSDE
start retrieve metadata
cool
Start of alignment for: SDEtest
ArcSDE harvest finished ///// after a couple of seconds
But, nothing have been harvested. I guess this could be due to my metadata
using a profile of ISO19115:2003. I have to check.
On Thu, May 7, 2009 at 3:26 PM, heikki <tropicano@anonymised.com> wrote:
hi,
software by ESRI. That's why they are not committed to Geonetwork SVN.They are :
concurrent.jar
icu4j_3_2.jar
jpe_sdk.jar
jsde_sdk.jarI don't know if all 4 are really necessary but of course I have not
your jsde9x.jar.They must be in, or under, /web/geonetwork/WEB-INF/lib, indeed, as Mathieu
told you. I'd say try putting your jar there and let us know how it goes..kind regards
Heikki DoelemanOn Thu, May 7, 2009 at 10:22 AM, Mathieu Coudert <
mathieu.coudert@anonymised.com> wrote:Hi,
HTH,Mathieu
> Hi all,
jsde9x.jar?
> Thanks to all,
> Walter
to
> i700
> GeoNetwork opensource - Metadata Catalog download | SourceForge.net
i700
E-mail: walter.simonazzi@anonymised.com
Direct phone: +34 93 581 3868
Fax: +34 93 581 3545
Secretary: +34 93 581 3518
http://terrestrial.eionet.europa.eu
hi,
cool ![]()
it looks like it doesn't find any metadata in your arcsde database .. if you
like, I'll send you a custom version containing some more logging. But not
today or tomorrow, as I'm too busy ... over the weekend should be possible.
On Thu, May 7, 2009 at 3:54 PM, Walter Simonazzi <walter.simonazzi@anonymised.com.>wrote:
connection to ArcSDE / 9.3, and this is what I get:Connect to ArcSDE
cool
ArcSDE harvest finished ///// after a couple of secondsBut, nothing have been harvested. I guess this could be due to my metadata
using a profile of ISO19115:2003. I have to check.On Thu, May 7, 2009 at 3:26 PM, heikki <tropicano@anonymised.com> wrote:
hi,
concurrent.jar
icu4j_3_2.jar
jpe_sdk.jar
Mathieu told you. I'd say try putting your jar there and let us know how it
goes..kind regards
HTH,Mathieu
> Hi all,
jsde9x.jar?
> Thanks to all,
> Walter
Your
to
KODAK
> i700
to
i700
http://sourceforge.net/projects/geonetwork--
--Walter Simonazzi
European Topic Centre on Land Use and Spatial Information Torre C5-S, 4ª
planta
Edifici C- Facultat de Ciències Universitat Autònoma de Barcelona
08193 Bellaterra (Barcelona)
SpainE-mail: walter.simonazzi@anonymised.com
if you look in src\org\fao\geonet\arcgis\ArcSDEMetadataAdapter.java you can
see in which tables it looks for metadata and using which criteria.
it uses table : SDE.GDB_USERMETADATA
looking in column : SDE.GDB_USERMETADATA.XML
and only retrieves data from that column if it contains the string
"MD_Metadata".
Hope this helps,
Heikki Doeleman
On Thu, May 7, 2009 at 3:57 PM, heikki <tropicano@anonymised.com> wrote:
hi,
cool
you like, I'll send you a custom version containing some more logging. But
not today or tomorrow, as I'm too busy ... over the weekend should be
possible.On Thu, May 7, 2009 at 3:54 PM, Walter Simonazzi <walter.simonazzi@anonymised.com...>wrote:
cool
hi,
concurrent.jar
icu4j_3_2.jar
jpe_sdk.jar
goes..kind regards
HTH,Mathieu
> Hi all,
jsde9x.jar?
> Thanks to all,
> Walter
Your
thanks to
KODAK
> i700
to
i700
--Walter Simonazzi
planta
It would be of a great help. Thanks heikki.
The thing is that I have metadata in my ArcSDE, but I said..maybe the
problem is in my metadata files.
hi,
cool
cool
hi,
concurrent.jar
icu4j_3_2.jar
jpe_sdk.jar
goes..kind regards
HTH,Mathieu
> Hi all,
jsde9x.jar?
> Thanks to all,
> Walter
Your
thanks to
KODAK
> i700
to
i700
GeoNetwork opensource - Metadata Catalog download | SourceForge.net--
--Walter Simonazzi
planta
Yes Miller. In sdetune Arcsde is configured to use SDEbinary...but I don't see the problem in doing that, could you give more details?
C.C. Miller wrote:
Could it be your XML column is configured as binary in sdetune?
Sent from iPhone
On May 7, 2009, at 10:03 AM, Walter Simonazzi <walter.simonazzi@anonymised.com> wrote:
problem is in my metadata files.On Thu, May 7, 2009 at 3:57 PM, heikki <tropicano@anonymised.com> wrote:
hi,
cool
possible.On Thu, May 7, 2009 at 3:54 PM, Walter Simonazzi <walter.simonazzi@anonymised.com>wrote:
cool
hi,
concurrent.jar
icu4j_3_2.jar
jpe_sdk.jar
goes..kind regards
HTH,Mathieu
from....well, through ArcSDE. Does anyone knows where to put thejsde9x.jar?
Thanks to all,
Walter
Your
thanks to
KODAK
i700
GeoNetwork opensource - Metadata Catalog download | SourceForge.net------------------------------------------------------------------------------
to
i700
Walter Simonazzi
planta
http://terrestrial.eionet.europa.eu--
Walter Simonazzi
planta
------------------------------------------------------------------------------The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
Kodak, there's a perfect scanner to get the job done! With the NEW KODAK i700
GeoNetwork OpenSource is maintained at GeoNetwork opensource - Metadata Catalog download | SourceForge.net
E-mail: walter.simonazzi [at] uab.es
Walter, sorry to be so coy but I was just out walking around and didn't have too many facts available in my little brain. (Evidence? I meant "dbtune" and not "sdetune.")
Anyway, quoting from http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Configuring_a_PostgreSQL_database_to_support_XML_columns&anchor=cs164785 :
"The XML_DOC_UNCOMPRESSED_TYPE configuration parameter determines how the contents of XML documents will be stored. You can use either BINARY (a compressed storage type) or TEXT (an uncompressed storage type). If you use BINARY, data is stored as bytea data type. If you use TEXT, the data will be either Unicode or ASCII, depending on whether your database is set to store Unicode data (UTF-8) or not. If you are using ArcIMS Metadata Services, it is usually best to specify the BINARY type. However, if you are interested in building an index on the XML column in addition to the one created for the Metadata Service, you may want to use the uncompressed TEXT type so the information can be read directly.
For definitions of all the XML parameters for PostgreSQL, see the XML parameter section of PostgreSQL DBTUNE configuration parameters."
Obviously that's from the PostgreSQL help area, but I gather it's true for other RDBMSs as well. Plus, I'm not sure this is really the problem. Worth a try, though, and I'm excited to see you get through this issue.
Chris
Sent from iPhone
On May 7, 2009, at 10:03 AM, Walter Simonazzi <walter.simonazzi@anonymised.com.> wrote:
hi,
cool
possible.On Thu, May 7, 2009 at 3:54 PM, Walter Simonazzi <walter.simonazzi@anonymised.com567...>wrote:
cool
hi,
concurrent.jar
icu4j_3_2.jar
jpe_sdk.jar
goes..kind regards
HTH,Mathieu
Thanks to all,
Walter
Your
thanks to
KODAK
i700
http://sourceforge.net/projects/geonetwork------------------------------------------------------------------------------
to
i700
Walter Simonazzi
planta
Walter Simonazzi
planta
GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork--
Walter Simonazzi
European Topic Centre on Land Use and Spatial Information Torre C5-S, 4ª planta
SpainE-mail: walter.simonazzi [at] uab.es
