Hi Everyone,
I am trying to batch import from ArcCatalog XML metadata. I tried exporting
single xml metadata from ArcCatalog (they are ArcIMS data layers, with FGDC
metadata), but then there is no combination of settings that allows me to
import it in geonetwork by using the XML paste window. I saw threads on this
forum linking to tools Jeroen had published online, to transform the XML
info into something geonetwork will import,but the link is dead.
http://193.43.36.138/software/tools/releases
I also tried to follow this link -
http://webhelp.esri.com/arcgisdesktop/9.1/body.cfm?tocVisable=1&ID=-1&TopicName=Customizing%20metadata
, but this link is also dead.
I am wondering if someone can help me figure out how to import into
geonetwork from ArcCatalog, and especially how to do this in batch, since i
don't want to have to export every single metadata file from my ArcIMS
server (there are many).
Any help is appreciated.
Thanks.
Giuseppe
View this message in context: http://www.nabble.com/Batch-import-from-ArcIMS-Arc-Catalog-9.3-tp20431356p20431356.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
