Hi folks,
I am new to Geonetwork, and I find myself a bit stuck as I cannot find any information about this particular issue.
I need to customize the Minimap for simple searching. I have found that it is relatively easy to add new map content to both the main Map Viewer and the Minimap on the main page (simple WMS layers). But I want to change the associated option values in the region_simple select and have the new values bound to regions on the new map I set up for the main page. For example, I would like to have the map limited to the United States and have all 52 state names in the dropdown. Obviously, when I select a state name, Alaska for example, Alaska would be highlighted and the map would zoom, etc... Is this possible? I found one post that alludes to this issue but does not address it directly. In that post, it was mentioned that the option values in the region_simple select were hard-coded in some java class. Is this accurate? If so, it would seem that these dropdown values are not configurable, but would require us to edit the source code and recompile Geonetwork. Is this accurate?
Any help would be much appreciated.
Travis Brannon
GIS Software Engineer
[cid:image001.jpg@anonymised.com]
[cid:image002.jpg@anonymised.com]
A 36 Triq ir Russett | Kappara | SGN 4433 | Malta
T +356 21350066 F +356 21350070 E travisb@anonymised.com<mailto:travisb@anonymised.com> W www.isys.com.mt<http://www.isys.com.mt/>
This e-mail and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this e-mail in error please notify the sender. Please note that any views or opinions presented in this e-mail are solely those of the author and do not necessarily represent those of the company. Finally, the recipient should check this e-mail and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this e-mail.
(attachments)
