I am currently running the
http://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v2.6.3/geonetwork-install-2.6.3-0.jar/download
geonetwork-install-2.6.3-0.jar (Current release) version of GeoNetwork. I
changed the connector in jetty.xml so the default port is 80, so when I go
to http://geoserver.myexampleserver.com/geonetwork it works.
I however would like to be able to go to
http://geoserver.myexampleserver.com without adding the /geonetwork and have
geonetwork work?
Is there any way to do this natively, or will I have to install apache and
set up rewrite rules?
Alternatively, is there a way to redirect the default root page:
Error 404 - Not Found.
No context on this server matched or handled this request.
Contexts known to this server are: ...
to automaticly redirect to /geonetwork ?
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Can-I-run-GeoNetwork-at-the-document-root-tp6177064p6177064.html
