I'm working on Geonetwork 3.4.0 and I have some metadata files generated by
ArcGIS 10.5.
The XML files are stocked into a folder that I would like to harvest.
But when harvesting, it says "badFormat" and doesn't load anything.
If I import manually through "Import new records", the records are imported
without issues.
It tried it with 3.4.0 and 3.4.1 versions. Please find below an example
record.
Is that the expected behaviour or a bug ?
Best regards from France,
Nicolas Roelandt
*Example:*
<MD_Metadata xmlns="http://www.isotc211.org/2005/gmd" xmlns:gco="
http://www.isotc211.org/2005/gco" xmlns:gts="
http://www.isotc211.org/2005/gts" xmlns:srv="
http://www.isotc211.org/2005/srv" xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance">
<language>
<LanguageCode codeList="
http://www.loc.gov/standards/iso639-2/php/code_list.php"
codeListValue="fre" codeSpace="ISO639-2">fre</LanguageCode>
</language>
<characterSet>
<MD_CharacterSetCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_CharacterSetCode"
codeListValue="utf8" codeSpace="ISOTC211/19115">utf8</MD_CharacterSetCode>
</characterSet>
<hierarchyLevel>
<MD_ScopeCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_ScopeCode"
codeListValue="dataset" codeSpace="ISOTC211/19115">dataset</MD_ScopeCode>
</hierarchyLevel>
<hierarchyLevelName>
<gco:CharacterString>dataset</gco:CharacterString>
</hierarchyLevelName>
<contact>
<CI_ResponsibleParty>
<individualName>
<gco:CharacterString>DE INT</gco:CharacterString>
</individualName>
<organisationName>
<gco:CharacterString>STIF</gco:CharacterString>
</organisationName>
<contactInfo>
<CI_Contact>
<address>
<CI_Address>
<electronicMailAddress>
<gco:CharacterString>example@anonymised.com</gco:CharacterString>
</electronicMailAddress>
</CI_Address>
</address>
</CI_Contact>
</contactInfo>
<role>
<CI_RoleCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_RoleCode"
codeListValue="pointOfContact"
codeSpace="ISOTC211/19115">pointOfContact</CI_RoleCode>
</role>
</CI_ResponsibleParty>
</contact>
<dateStamp>
<gco:Date>2018-03-21</gco:Date>
</dateStamp>
<metadataStandardName>
<gco:CharacterString>ISO 19139 Geographic Information - Metadata -
Implementation Specification</gco:CharacterString>
</metadataStandardName>
<metadataStandardVersion>
<gco:CharacterString>2007</gco:CharacterString>
</metadataStandardVersion>
<spatialRepresentationInfo>
<MD_VectorSpatialRepresentation>
<topologyLevel>
<MD_TopologyLevelCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_TopologyLevelCode"
codeListValue="geometryOnly"
codeSpace="ISOTC211/19115">geometryOnly</MD_TopologyLevelCode>
</topologyLevel>
<geometricObjects>
<MD_GeometricObjects>
<geometricObjectType>
<MD_GeometricObjectTypeCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_GeometricObjectTypeCode"
codeListValue="composite"
codeSpace="ISOTC211/19115">composite</MD_GeometricObjectTypeCode>
</geometricObjectType>
<geometricObjectCount>
<gco:Integer>146</gco:Integer>
</geometricObjectCount>
</MD_GeometricObjects>
</geometricObjects>
</MD_VectorSpatialRepresentation>
</spatialRepresentationInfo>
<referenceSystemInfo>
<MD_ReferenceSystem>
<referenceSystemIdentifier>
<RS_Identifier>
<code>
<gco:CharacterString>2154</gco:CharacterString>
</code>
<codeSpace>
<gco:CharacterString>EPSG</gco:CharacterString>
</codeSpace>
<version>
<gco:CharacterString>6.16(9.0.0)</gco:CharacterString>
</version>
</RS_Identifier>
</referenceSystemIdentifier>
</MD_ReferenceSystem>
</referenceSystemInfo>
<identificationInfo>
<MD_DataIdentification>
<citation>
<CI_Citation>
<title>
<gco:CharacterString>Etablissements Publics de Coopération
Intercommunale</gco:CharacterString>
</title>
<date>
<CI_Date>
<date>
<gco:Date>2016-04-25</gco:Date>
</date>
<dateType>
<CI_DateTypeCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode"
codeListValue="creation"
codeSpace="ISOTC211/19115">creation</CI_DateTypeCode>
</dateType>
</CI_Date>
</date>
<identifier>
<MD_Identifier>
<code>
<gco:CharacterString>test</gco:CharacterString>
</code>
</MD_Identifier>
</identifier>
<citedResponsibleParty>
<individualName>
</individualName>
<organisationName>
</organisationName>
<role>
</role>
</citedResponsibleParty>
<presentationForm>
<CI_PresentationFormCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_PresentationFormCode"
codeListValue="mapDigital"
codeSpace="ISOTC211/19115">mapDigital</CI_PresentationFormCode>
</presentationForm>
</CI_Citation>
</citation>
<abstract>
<gco:CharacterString>La couche est issue du regroupement des
emprises communales à partir de la description des EPCI du ministère de
l'interieur (source:
www.collectivites-locales.gouv.fr/liste-et-composition-des-epci-a-fiscalite-propre).Tous
les EPCI des communes concernées par la zone de desserte du STIF (y compris
hors Ile-de-France) sont décrites intégralement.</gco:CharacterString>
</abstract>
<purpose>
<gco:CharacterString>Emprises des Etablissements Publics de
Coopération Intercommunale en Ile-de-France.</gco:CharacterString>
</purpose>
<credit>
<gco:CharacterString>test, www.collectivites-locales.gouv.fr
</credit>
<pointOfContact>
<individualName>
</individualName>
<organisationName>
</organisationName>
<contactInfo>
<CI_Contact>
<address>
<CI_Address>
<gco:CharacterString>example.mail.com
</CI_Address>
</address>
</CI_Contact>
</contactInfo>
<role>
</role>
</pointOfContact>
<resourceMaintenance>
<MD_MaintenanceInformation>
<maintenanceAndUpdateFrequency>
<MD_MaintenanceFrequencyCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_MaintenanceFrequencyCode"
codeListValue="annually"
codeSpace="ISOTC211/19115">annually</MD_MaintenanceFrequencyCode>
</maintenanceAndUpdateFrequency>
</MD_MaintenanceInformation>
</resourceMaintenance>
<descriptiveKeywords>
<MD_Keywords>
<keyword>
<gco:CharacterString>Downloadable Data</gco:CharacterString>
</keyword>
<thesaurusName uuidref="723f6998-058e-11dc-8314-0800200c9a66" />
</MD_Keywords>
</descriptiveKeywords>
<MD_Keywords>
<keyword>
<gco:CharacterString>EPCI collectivités CA CC SAN Métropole
Metropole</gco:CharacterString>
</keyword>
</MD_Keywords>
<resourceConstraints>
<MD_Constraints>
<useLimitation>
</useLimitation>
</MD_Constraints>
</resourceConstraints>
<MD_SecurityConstraints>
<classification>
<MD_ClassificationCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_ClassificationCode"
codeListValue="unclassified"
codeSpace="ISOTC211/19115">unclassified</MD_ClassificationCode>
</classification>
</MD_SecurityConstraints>
<spatialRepresentationType>
<MD_SpatialRepresentationTypeCode codeList="
http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_SpatialRepresentationTypeCode"
codeListValue="vector"
codeSpace="ISOTC211/19115">vector</MD_SpatialRepresentationTypeCode>
</spatialRepresentationType>
<language>
</language>
<characterSet>
</characterSet>
<topicCategory>
<MD_TopicCategoryCode>boundaries</MD_TopicCategoryCode>
</topicCategory>
<topicCategory>
<MD_TopicCategoryCode>transportation</MD_TopicCategoryCode>
</topicCategory>
<environmentDescription>
<gco:CharacterString> Version 6.2 (Build 9200) ; Esri ArcGIS
10.5.1.7333</gco:CharacterString>
</environmentDescription>
<extent>
<EX_Extent>
<geographicElement>
<EX_GeographicBoundingBox>
<extentTypeCode>
<gco:Boolean>true</gco:Boolean>
</extentTypeCode>
<westBoundLongitude>
<gco:Decimal>0.912372</gco:Decimal>
</westBoundLongitude>
<eastBoundLongitude>
<gco:Decimal>3.775548</gco:Decimal>
</eastBoundLongitude>
<southBoundLatitude>
<gco:Decimal>47.748689</gco:Decimal>
</southBoundLatitude>
<northBoundLatitude>
<gco:Decimal>49.543602</gco:Decimal>
</northBoundLatitude>
</EX_GeographicBoundingBox>
</geographicElement>
</EX_Extent>
</extent>
</MD_DataIdentification>
</identificationInfo>
<distributionInfo>
<MD_Distribution>
<distributionFormat>
<MD_Format>
<name>
<gco:CharacterString>SDE Feature Class</gco:CharacterString>
</name>
<version>
</version>
</MD_Format>
</distributionFormat>
<transferOptions>
<MD_DigitalTransferOptions>
<transferSize>
<gco:Real>6.139</gco:Real>
</transferSize>
</MD_DigitalTransferOptions>
</transferOptions>
<transferOptions>
<MD_DigitalTransferOptions />
</transferOptions>
</MD_Distribution>
</distributionInfo>
<dataQualityInfo>
<DQ_DataQuality>
<scope>
<DQ_Scope>
<level>
</level>
</DQ_Scope>
</scope>
<report>
<DQ_DomainConsistency>
<result>
<DQ_ConformanceResult>
<specification>
<CI_Citation>
<title>
<gco:CharacterString>Test</gco:CharacterString>
</title>
<date>
<CI_Date>
<date>
</date>
<dateType>
</dateType>
</CI_Date>
</date>
</CI_Citation>
</specification>
<explanation gco:nilReason="missing" />
<pass>
</pass>
</DQ_ConformanceResult>
</result>
</DQ_DomainConsistency>
</report>
<lineage>
<LI_Lineage>
<statement>
</statement>
</LI_Lineage>
</lineage>
</DQ_DataQuality>
</dataQualityInfo>
<metadataMaintenance>
</metadataMaintenance>
</MD_Metadata>
<https://twitter.com/RoelandtN42>
