Hello,
Is it possible to export to MEF files all metadata contained in GN using a
command-line sentence or tool?
Anyway, in GN 2.6.2 GASP does not seem to have export tool, right?
Thank you very much.
Nacho Varela
Hello,
Nacho Varela
(...) in GN 2.6.2 GASP does not seem to have export tool, right?
I've had to configure properly the GN 2.6.2 folder. GAST has the graphical
export tool.
Any way to export to MEF format on command-line?
Thank you very much,
Nacho Varela
Hi Nacho
You can also do the export from GeoNetwork GUI: login as Administrator, make
an empty search to retrieve all metadata, select it and check *Actions on
selection* > *Export (ZIP)*. This option creates a MEF file with all
metadata records selected.
I think no command line tool, but using GeoNetwork XML services (see
developer manual) should not be much complicate to develop it.
Jose García
GeoCat bv
export tool.Is it possible to export to MEF files all metadata contained in GN using a
Any way to export to MEF format on command-line?Thank you very much,
Nacho Varela------------------------------------------------------------------------------
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-users mailing list
Anyone know why I do not see the option to *Export (ZIP)* between *Actions
on selection*? I can only view the following options: *Delete*, *New
Owner*,*Update categories*,*Update privileges* and *Display selected only*
Inma,
-----Mensaje original-----
De: jose garcia [mailto:josegar74@anonymised.com]
Enviado el: jueves, 13 de enero de 2011 17:46
Para: Nacho Uve
CC: geonetwork-users@lists.sourceforge.net
Asunto: Re: [GeoNetwork-users] Command-line MEF export
Hi Nacho
Jose García
GeoCat bv
Nacho Varela
