[GeoNetwork-users] Comparison between Geonetwork and ESRI Geoportal Server
- I am new to Geonetwork and ESRI Geoportal Server (Both it's commercial &
Open Source products).
  I am caring out a comparative study between Geonetwork, ESRI Geoportal
toolkit 9.3.1 / Extension 10 (Commercial) and ESRI Geoportal Server (Open
source).
  I have gone through their user & developer manuals but still there are
few things which are not clear specially at technical and architectural
level.
  Please if someone one can help me with the following queries, if not all
atleast with few. It would be of great help to understanding the level of
details.
   1. *What is the security at application level (e.g. Particular data
   access to an individual in a group, etc.) and system level (e.g. Can
   individual Nodes have full access to all hierarchies within the portal)
   in Geonetwork?*
   2. *****Is the security level the same in ESRI Geoportal Server (both
   Commercial and Open source products) and Geonetwork?***
   3. * What are the functionalities in Geonetwork that is not present in
   ESRI Geoportal Server and vice versa?***
   4. *Can ArcGIS Server be used with Geonetwork? ***
   5. * Is Geonetwork compatible with Sun Solaris?***
   6. *Other then the cost why organizations prefer open source like
   Geonetwork?*
   7. *What is special about Geonetwork that the organization must go for
   it rather than ESRI Geoportal Server which is also an open source?*
   8. ***What is the difference between ArcGIS Server and ArcGIS Server
   Online. (From Architecture & Services point of view)*
   9. *If both are providing the same services and functionalities then why
   one should opt for ArcGIS Server which is very costly and maintenance is
   also an issue.*
   10. *Can we also connect with other ESRI products via Geonetwork. *
* For example:
                            a. Direct modification of vector or raster
layer from ArcMap or any other such tool/technology
                            b. Directly updating Metadata from ArcCatolog
or any such other tool/technology.
                            c. Or any other map viewer like ArcExplorer,
ArcGlobe, ArcScene, etc.?
** 11. Can we also connect with other ESRI products via ESRI Geoportal
Server which is an open source. **
            For example:
                            c. Or any other map viewer like ArcExplor1er,
ArcGlobe, ArcScene, etc.?*
    12.* If Both ESRI Geoportal i.e. commercial and ESRI Geoportal i.e.
open source provides the same services and functionalities then why
companies/organization go for the commercial which is very expensive**.*
*Saher Murad*
GIS Developer
IMMAP
Islamabad, Pakistan
Email: smurad@anonymised.com
Website: www.immap.org
Facebook: http://www.facebook.com/immap.org
Skype: saher.murad
will you share the results ?
Regards.
On Fri, May 11, 2012 at 6:10 AM, Saher Murad <smurad@anonymised.com> wrote:
source).
level.
details.
  in Geonetwork?*
  Geonetwork?*
  also an issue.*
* For example:
           For example:
*Saher Murad*
GIS Developer
IMMAP
Islamabad, Pakistan
Skype: saher.murad
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-users mailing list
I found this this morning:
http://gridnairobi.unep.org/chm/africa_programme/GeoNetwork_and_ESRI_GIS_Portal_Toolkit_Comparison-GDNBI3027.pdf
Pierre
-----Original Message-----
Sent: Friday, May 11, 2012 1:10 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] Comparison between Geonetwork and ESRI
Geoportal Server
source).
level.
details.
   in Geonetwork?*
   Geonetwork?*
   also an issue.*
* For example:
            For example:
*Saher Murad*
GIS Developer
IMMAP
Islamabad, Pakistan
Skype: saher.murad
Hi Pierre and Saher,
That is a very old comparison sheet. FGDC has a more recent comparison between multiple catalog software, but even that one is old already.
Saher, beside the notes I did send you before I think some of your questions were more suitable for an ESRI forum. They really focus on Esri products.
Kind regards,
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
HTTP://GeoCat.net
Send from mobile phone.
Op 11 mei 2012 om 19:47 heeft Pierre Racine <Pierre.Racine@anonymised.com> het volgende geschreven:
Pierre
Geoportal Server
source).
level.
details.
  in Geonetwork?*
  Geonetwork?*
  also an issue.*
* For example:
           For example:
*Saher Murad*
GIS Developer
IMMAP
Islamabad, Pakistan
Facebook: iMMAP Inc.
Skype: saher.murad
Thank you Jeroen, the notes you sent were very helpful and I'm posting the
question with little modifications to both ESRI & Geonetwork forums to get
experts ideas, as designing SDI is a big thing and we want to be clear at
each level of detail.
Pierre, I had earlier gone through the GeoSUR comparison sheet, but it
didn't answer my queries.
Please share more details which i might have missed even in my questions
and that you consider to be important for SDI.
On 12 May 2012 03:54, Jeroen Ticheler <jeroen.ticheler@anonymised.com> wrote:
products.
Kind regards,
Jeroen
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
HTTP://GeoCat.net
> Pierre
>> From: Saher Murad [mailto:smurad@anonymised.com]
>> Geoportal Server
>> Hi,
commercial &
(Open
>> source).
>> level.
all
of
>> details.
portal)
>> in Geonetwork?*
>> Geonetwork?*
why
is
>> also an issue.*
>> * For example:
Geoportal
>> For example:
>> Regards,
>> *Saher Murad*
>> GIS Developer
>> IMMAP
>> Islamabad, Pakistan
>> Skype: saher.murad
Discussions
malware
>> _______________________________________________
*Saher Murad*
GIS Developer
IMMAP
Islamabad, Pakistan
Skype: saher.murad
