[GeoNetwork-users] CSW harvesting GN (was: category vs. TopicCategory queryable)
I'm working with Charlton (see his original message below). My suspicion is that what we are trying to do is not possible, but it would be very helpful if someone can confirm that >
Basically what we would like to do is perform a CSW harvest that pulls out GeoNetwork records based on the GN 'category' I've assigned (not the ISO 'topicCategory'). Category appears in the info.xml not the metadata.xml for a given record.
We have been able to harvest using the CSW properyName of 'any' or 'subject' for text in the metadata, but that does not appear to grab anything that is in the info.xml.
Anyone have knowledge/experience on this?
Kathy
-----Original Message-----
From: Charlton Galvarino [mailto:charlton@anonymised.com]
Sent: Wednesday, October 29, 2014 1:27 PM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] category vs. TopicCategory queryable
Hi, GN team.
I am trying to consume GN search results. I'd prefer to stick w/ CSW, but I'm having a tough time w/ categories.
If I perform a GET xml.search?category=dataportal, I see some results, e.g.:
<metadata>
  <metadatacreationdate/>
  <geonet:info xmlns:geonet="http://www.fao.org/geonetwork&quot;&gt;
    <id>36614</id>
    <uuid>64cd3cb6-3a74-4990-8772-4af8b0714b1a</uuid>
    <schema>iso19139</schema>
    <createDate>2014-10-08T18:57:23</createDate>
    <changeDate>2014-10-08T18:57:23</changeDate>
    <source>e3dbbdf2-e706-43dd-a16e-1400d678044f</source>
    <category>dataportal</category>
    <selected>false</selected>
    <category internal="true">dataset</category>
  </geonet:info>
</metadata>
But if I perform a CSW POST query, I don't get any results at all.
<csw:Constraint version="1.1.0">
  <Filter xmlns="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot;&gt;
    <PropertyIsLike wildCard="%" singleChar="_" escape="\\">
      <PropertyName>TopicCategory</PropertyName>
      <Literal>dataportal</Literal>
    </PropertyIsLike>
  </Filter>
</csw:Constraint>
The CSW GetCapabilities advertises TopicCateogry, but I'm not convinced they are one and the same. I can get CSW results if I use other searches, e.g. Title, though, so I don't believe CSW is holding me up.
In a nutshell, how can I pull back category-specific results w/ a CSW query?
TIA.
Charlton Galvarino
1 (803) 233-6205 : voice
1 (803) 223-9579 : fax
P.O. Box 50960
Columbia, SC 29250
GeoNetwork-users mailing list
Hi Kathy,
Not an expert on this, but I believe GN categories is something specific to GN, while CSW is an open standard. Thus, GN categories wouldn't be available through CSW.
A workaround would be to quit using GN categories, and replace it by a hand-made thesaurus, in which you put your "categories".
Categories would then be with the other keywords and available with CSW.
Hope this helps,
Jean
Kathy
Hi, GN team.
<metadata>
     <id>36614</id>
   </geonet:info>
</metadata>
     </PropertyIsLike>
   </Filter>
</csw:Constraint>
TIA.
Charlton Galvarino
P.O. Box 50960
Columbia, SC 29250
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Thanks Jean. That's where we were leaning but wanted to be sure there wasn't an easier way.
Kathy
_____________________________________
Kathy Koch
Data Curator
Contractor (LimnoTech / GLOS)
501 Avis Drive, Ann Arbor, MI 48108
Office: 734-332-1200 email:kkoch@anonymised.com
LimnoTech www.limno.com
________________________________________
Sent: Tuesday, November 11, 2014 3:15 AM
Subject: Re: [GeoNetwork-users] CSW harvesting GN (was: category vs. TopicCategory queryable)
Hi Kathy,
Hope this helps,
Jean
Kathy
Hi, GN team.
<metadata>
     <id>36614</id>
   </geonet:info>
</metadata>
     </PropertyIsLike>
   </Filter>
</csw:Constraint>
TIA.
Charlton Galvarino
P.O. Box 50960
Columbia, SC 29250
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktrk
