i'm trying the transaction functions with CSW protocol.
Is there any constraint about the uuid (metadata identifier?)
Everything works if the idenfier is something like
bf7ab961-a69f-48e9-a6da-61c207de86d6
I can insert and delete metadata.
The problem comes when I try to use an identifier like
AAA_BBB_CCC_20100101203020
(so characters, numbers and some underscore).
I can insert correctly the metadata, but I can't delete it.
Any ideas?
Regards
Marco
On Thu, 28 Jan 2010 17:44:18 +0100
Marco Vimercati wrote:
I believe that the system expects the UUID to adhere to it specified
format.
http://en.wikipedia.org/wiki/Universally_Unique_Identifier
TSW
Any ideas?
Regards
Marco
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
GeoNetwork-users mailing list
Trevor Wiens
twiens@anonymised.com
Whatever you can do, or dream you can, begin it. Boldness has genius,
power, and magic in it.
Hi all
format.
mmm ok. But it's strange that it accept other formats on 'insert' but not
in 'delete'....
Anyway I said UUID because I looked into the code, finding uuid... but in the
metadata that field is called 'fileIdentifier', so I supposed I can insert
something else.
thanx
marco
Hello
2010/1/28 Marco Vimercati <mvimercati@anonymised.com>:
Can you find the record using a GetRecords operation with a filter on
UUID after insert ?
You could check the value of the uuid in the index using Luke maybe to
see if "_" or upper case letter is the problem ?
Cheers.
Francois
Any ideas?
Regards
Marco
Hello Francois,
I tried with GetRecordbyID and I can find the metadata.
I also looked into the DB and the identifier is stored correctly.
Just csw delete gives the problem.
regards
Marco
Hello
> Hi all,
UUID after insert ?
Cheers.
Francois
> Any ideas?
> Regards
> Marco
>----- The Planet: dedicated and managed hosting, cloud storage, colocation
> business Choose flexible plans and management services without long-term
> contracts Personal 24x7 support from experience hosting pros just a phone
> call away. http://p.sf.net/sfu/theplanet-com
________________________________________
Marco Vimercati
Earth Observation Dept
Tel. +39.0238048.241
Fax +39.023086458
Email mvimercati@anonymised.com
Carlo Gavazzi Space S.p.A.
Via Gallarate, 150 - 20151 Milano MI - Italy
http://www.cgspace.it
<< Le informazioni contenute in questo messaggio di posta elettronica e
relativi allegati sono riservate e confidenziali e ne è vietata la diffusione
in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il
presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene
gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96
e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali
<< This e-mail is confidential and may well also be legally privileged. If you
have received it in error, you are on notice of its status. Please notify us
immediately by reply e-mail and then delete this message from your system.
Please do not copy it or use it for any purposes, or disclose its contents to
any other person: to do so could be a breach of confidence. Thank you for
your co-operation. Please contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici@anonymised.com if you need assistance>>
