[GeoNetwork-users] Customize CSV export
Hello,
I would like to customize the fields in the CSV export. I am working with
a new installation of version of 3.2.1.
This page indicates that the place to do this is
GEONETWORK_DATA_DIR/config/schema_plugins/iso19139/present/metadata-iso19139.xsl.
However, this file does not appear in the current version of my application.
A prior version of GeoNetwork at my organization edited the
GEONETWORK_DATA_DIR/config/schema_plugins/iso19139/layout/tpl-brief.xsl
to customize the CSV output, but this doesn't seem to be working now. Also,
what is the purpose of tpl-csv.xsl file in the same location or its
relationship to tpl-brief.xsl?
Thanks!
Karen
Karen Majewicz
Geospatial Project Metadata Coordinator
John R. Borchert Map Library, University of Minnesota Libraries
Room s98
(612) 626-6182
Hi Karen
Afaik, the file to change should be GEONETWORK_DATA_DIR/config/
schema_plugins/iso19139/layout/tpl-brief.xsl, at least is the one used by
the csv.search service used in the option to export metadata to csv from
the UI.
Jose García
On Thu, Aug 10, 2017 at 7:01 PM, Karen Majewicz <majew030@anonymised.com> wrote:
Hello,
application.
Also,
Thanks!
Karen
Karen Majewicz
Room s98
(612) 626-6182
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv&gt;
<https://twitter.com/geocat_bv&gt;
<https://plus.google.com/u/1/+GeocatNetbv/posts&gt;Please consider the
environment before printing this email.*
Thanks for your reply. Oddly, I found that tpl-brief.xsl didn't seem to
affect the operation. I discovered that editing tpl-csv.xsl instead
worked.
Karen
On Wed, Aug 16, 2017 at 1:22 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Karen
the UI.
Jose García
Hello,
application.
Also,
Thanks!
Karen
Karen Majewicz
Room s98
(612) 626-6182
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
Karen Majewicz
Room s98
(612) 626-6182
