[GeoNetwork-users] DCAT status in Geonetwork
Hi Developer and User lists,
I'm about to start work on a project that might use the dcat plugin(s) for
Geonetwork, and I'm keen to evaluate how they are currently working.
My questions:
1) dcat2 (https://github.com/metadata101/dcat2) works afaict in Geonetwork
4 but seems limited compared to dcat 1.1 (
https://github.com/metadata101/dcat-ap1.1) in that dcat 1.1 contains
thesauri, a harvester and other things. The readme for dcat2 also says that
it's "related to the dcat 1.1 plugin.
2) So... does that mean I need to install them both, and is dcat 1.1 known
to work in Geonetwork 3.10 or (preferably) 4?
3) Or, does dcat2 work in Geonetwork 3.10?
Thanks
Jo
*Jo Cook*
t:+44 7930 524 155/twitter:@archaeogeek
Please note that currently I do not work on Friday afternoons. For urgent
responses at that time, please visit support.astuntechnology.com or phone
our office on 01372 744009
*Sign up to our mailing list
<https://astuntechnology.com/company/#email-updates&gt; for updates on news,
products, conferences, events and training*
Astun Technology Ltd, 120
Manor Green Road, Epsom, Surrey, KT19 8LN, UK
t:+44 1372 744 009 w:
astuntechnology.com <http://astuntechnology.com/&gt; twitter:@astuntech
<https://twitter.com/astuntech&gt;
iShare - enterprise geographic
intelligence platform <https://astuntechnology.com/ishare/&gt;
GeoServer,
PostGIS and QGIS training <https://astuntechnology.com/training-courses/&gt;
Helpdesk and customer portal
<https://astuntech.atlassian.net/wiki/spaces/ISHAREHELP/pages/364970043/Astun+Technology+Support+Portal&gt;
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Hi Jo,
Le jeu. 28 janv. 2021 à 13:14, Jo Cook <jocook@anonymised.com> a
écrit :
My questions:
Geonetwork 4 but seems limited compared to dcat 1.1 (
https://github.com/metadata101/dcat2 is indeed "limited" for now (
https://github.com/metadata101/dcat2/issues/1) but the goal was to make it
generic and usable in any context. It does not depend on dcat-ap1.1.
https://github.com/metadata101/dcat-ap1.1 has a number of hard coded eg.
https://github.com/metadata101/dcat-ap1.1/blob/master/src/main/plugin/dcat-ap/update-fixed-info.xsl#L73
elements which makes it probably quite hard to use outside the scope it has
been done.
Jose made a "dutch" DCAT 2 profile for GN3 I think?
Cheers.
Francois
Thanks
Jo
*Jo Cook*
Astun Technology Ltd, 120 Manor Green Road, Epsom, Surrey, KT19 8LN, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
864201149.
GeoNetwork-devel mailing list
Hi Everyone,
Thanks for your responses. I will explore what to do next and assist where
I can.
Jo
On Fri, Jan 29, 2021 at 8:53 AM Nolf Geraldine <geraldine.nolf@anonymised.com>
wrote:
Hello Jo, all,
In Flanders we developed the dcat-ap 1.2 plugin (the second link out of
your question below), with the Open Data community in mind (so basically
not the generic 1.2 but the template for the open community, more strict on
some elements then the generic DCAT-AP 1.2 (keywords, thesauri, licences,
formats, ...) and this plugin is compatible up until GeoNetwork version
3.8.3. It was not tested on further GeoNetwork versions.
Here is he link where you can explore both Open (1390) and Geo (6150)
metadata records (7540 in total) in that one GeoNetwork instance:
https://metadata.vlaanderen.be/. (Including 4 CSW-harvests, 10
DCAT-feeds.)
Metadata Vlaanderen then is harvested in our Geoportal from the
ISO-language trough a CSW-harvest. But the same Metadata Vlaanderen
instance is harvested to our Open data portal from the DCAT-language trough
a DCAT-RDF-feed, where the Open geodata is exported via the GeoDCAT-AP way
into RDF as well.
As for dcat-ap 2.0, we were not aware of the state of this repo:
https://github.com/metadata101/dcat2.
However we are currently on the early development phase of a new plugin
implementing a customized version of dcat-ap 2.0 standard (for GeoNetwork
3.8.3 too). XML-schema is created, editor too. Validation and export still
to be worked on.
It is based on the dcat-ap 1.2 plugin for the dataset-part with (mostly)
the addition of dcat services metadata.
The model we are using to implement you can find here:
https://data.vlaanderen.be/doc/applicatieprofiel/metadata-dcat/. This
model is to read together with DCAT-AP2.0 => the 6 working groups we had in
Flanders, discussed in which fields to adopt from DCAT-AP 2.0; make Dutch
definitions for them; tells us which fields we should make extra mandatory,
or keep it optional as DCAT-AP 2.0 describes; have more restrictions or
code lists behind certain elements; ...
The Idea is that this new pug-in will replace the 1.2 plugin. (We hope to
be able to do this in the coming months - maybe March). The new DCAT-AP 2.0
model is backwards compatible with the 1.2. And installing the 2 plug-ins
together on the same GeoNetwork instance will probably fail... For the new
development (2.0) we used therefore another instance of GeoNetwork.
There is no open-source repository for this 2.0 plugin yet but if you are
interested, we can push the source somewhere already.
Because we really would like to share it with the community, bring it back
into the core, so that the community can use our efforts already, build on
this further, and everybody can stick close to the GeoNetwork core for this
DCAT-language as well. That way everybody can share development & effort.
Because there is a lot on the backlog for this version of DCAT-AP 2.0
plug-in and integration with the GeoNetwork core:
- make the DCAT-AP 2.0 plug-in proof for further versions (then 3.8.3) of
- add the DCAT-AP 2.0 into the GeoNetwork API
- work on the export from ISO to GeoDCAT 2.0 instead of 1.2
So we are very willing to help & work together.
Kind regards,
Met vriendelijke groeten,
Geraldine Nolf
Teamcoach Datamanagement, Product Owner Metadata en DataPublicatie
Afdeling Gegevens- en dienstenintegratie
INFORMATIE VLAANDEREN
Havenlaan 88, 1000 Brussel
Koningin Maria Hendrikaplein 70, 9000 Gent
overheid.vlaanderen.be/informatie-vlaanderen | www.geopunt.be
Stel je vraag aan de overheid!
Bel gratis 1700 of surf naar www.vlaanderen.be
-----Oorspronkelijk bericht-----
Van: Jo Cook <jocook@anonymised.com>
Verzonden: donderdag 28 januari 2021 13:13
Aan: Devel geonetwork-devel@lists.sourceforge.net <
geonetwork-devel@lists.sourceforge.net>;
Geonetwork-Users@anonymised.com
Onderwerp: [GeoNetwork-users] DCAT status in Geonetwork
My questions:
1) dcat2 (
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fmetadata101%2Fdcat2&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229875726|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=lvA6%2FzCboR58ICIvTkMfkgUOHISjnxd9HONl8cNuS2E%3D&amp;reserved=0)
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fmetadata101%2Fdcat-ap1.1&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229875726|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=W3nNU6RF6zl7tc7ziGcrsXjAMfWWCpvTnMX%2BOUl5yOY%3D&amp;reserved=0)
in that dcat 1.1 contains thesauri, a harvester and other things. The
readme for dcat2 also says that it's "related to the dcat 1.1 plugin.
Thanks
Jo
*Jo Cook*
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fastuntechnology.com%2Fcompany%2F%23email-updates&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229875726|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=W2KvMLlVhYGzs4q3DYnyJjYHoiBMifg1U%2Fb6ZimTkLM%3D&amp;reserved=0&gt; for
updates on news, products, conferences, events and training*
https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fastuntechnology.com%2F&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229875726|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=G%2FFLD%2Fvk5k%2FXI%2FlxBvHsK8Nl5Onnq%2FRKE69BIci7u6U%3D&amp;reserved=0
> twitter:@astuntech <
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Ftwitter.com%2Fastuntech&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229885678|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=DNh%2Bup53S7%2FnSrGQ3PAGUAPc7VpbXFsL0BocpFDr1oU%3D&amp;reserved=0
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fastuntechnology.com%2Fishare%2F&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229885678|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=XP73pPxgAfkUSEKLtGicI%2BW1j6SSQcuoWwCMOmS1Q%2B8%3D&amp;reserved=0
GeoServer,
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fastuntechnology.com%2Ftraining-courses%2F&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229885678|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=VJQMKgtCHP23vV7I7jambFdlsUMIyMObBUlErFsHqDg%3D&amp;reserved=0
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Fastuntech.atlassian.net%2Fwiki%2Fspaces%2FISHAREHELP%2Fpages%2F364970043%2FAstun%2BTechnology%2BSupport%2BPortal&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229885678|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=fUz6XwPg2Mrn4%2BVR81VxVnRf6nyZDkYWv2xsmvOrADk%3D&amp;reserved=0
864201149.
GeoNetwork-users mailing list
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.sourceforge.net%2Flists%2Flistinfo%2Fgeonetwork-users&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229885678|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=Lchgj0qP80BJQyeKgwLyyyXAvl4YRD7t9rA4yiPvj70%3D&amp;reserved=0
https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fsourceforge.net%2Fprojects%2Fgeonetwork&amp;data=04|01|geraldine.nolf%40vlaanderen.be|b0b63a3a248640e5a01008d8c387510c|0c0338a695614ee8b8d64e89cbd520a0|0|0|637474333229885678|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|1000&amp;sdata=xgWpQUScZiwhOMDJ1iqM7ZGyfQJAXO2e9npHsVOj06I%3D&amp;reserved=0
*Jo Cook*
GeoServer,
864201149.
