Hi Andrew,
Have been out of the office for a few days, so apologies for the late
response. Nothing springs to mind, except the possibility that your
database has not be initialized with GAST. It seems though that you were
able to do this right`?
JPP
-----Original Message-----
From: Andrew Chamberlain [mailto:andyc@anonymised.com]
Sent: Monday, February 04, 2008 1:13 PM
To: Pickering, Jason
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] Sample Data Import Issue
Hi Jason,
Just to let you know, I've turned on the PostgreSQL logging of
connections, and there does seem to be a connection being made
successfully. This is the relevent excerpt from the log (written out
when the web interface is summoned for the first time):
LOG: connection authorized: user=csw database=geonetwork
Admittedly, I should have done this earlier to confirm the status of the
connection.
So given this, is there anything else which springs to mind that may be
causing the exceptions output when summoning the Geonetwork servlet home
page? This exception is accompanied by 2 javascript alerts in the
browser; "Sorry. There was an error" and "null". For completion, the
full output is provided below (apologies for the verboseness, but just
thought I'd be thorough).
Thanks again,
Andy
2008-02-04 12:44:39,208 INFO [jeeves.request] - HTML Request (from
81.149.82.182) : /geonetwork/srv/en/main.home
2008-02-04 12:44:39,209 DEBUG [jeeves.request] - Method : GET
2008-02-04 12:44:39,209 DEBUG [jeeves.request] - Content type : null
2008-02-04 12:44:39,209 DEBUG [jeeves.request] - Accept :
text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plai
n;q=0.8,image/png,*/*;q=0.5
2008-02-04 12:44:39,209 INFO [jeeves.service] - Dispatching : main.home
2008-02-04 12:44:39,209 DEBUG [jeeves.service] - -> no input parameters
2008-02-04 12:44:39,209 INFO [jeeves.service] - -> dispatching to
output for : main.home
2008-02-04 12:44:39,266 ERROR [jeeves.service] - Exception executing gui
service : java.lang.NullPointerException
2008-02-04 12:44:39,266 ERROR [jeeves.service] - (C) Stack trace is :
at org.fao.geonet.guiservices.util.Env.exec(Env.java:53)
at jeeves.server.dispatchers.guiservices.Call.exec(Call.java:75)
at
jeeves.server.dispatchers.AbstractPage.invokeGuiService(AbstractPage.jav
a:119)
at
jeeves.server.dispatchers.AbstractPage.invokeGuiServices(AbstractPage.ja
va:103)
at
jeeves.server.dispatchers.ServiceManager.dispatchOutput(ServiceManager.j
ava:584)
at
jeeves.server.dispatchers.ServiceManager.dispatch(ServiceManager.java:37
8)
at jeeves.server.JeevesEngine.dispatch(JeevesEngine.java:600)
at
jeeves.server.sources.http.JeevesServlet.execute(JeevesServlet.java:163)
at
jeeves.server.sources.http.JeevesServlet.doGet(JeevesServlet.java:88)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:697)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:810)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Applica
tionFilterChain.java:237)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilt
erChain.java:157)
at
org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilte
r.java:75)
at
tionFilterChain.java:186)
at
erChain.java:157)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValv
e.java:214)
at
org.apache.catalina.core.StandardValveContext.invokeNext(StandardValveCo
ntext.java:104)
at
org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:5
20)
at
org.apache.catalina.core.StandardContextValve.invokeInternal(StandardCon
textValve.java:198)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValv
e.java:152)
at
ntext.java:104)
at
org.jboss.web.tomcat.security.CustomPrincipalValve.invoke(CustomPrincipa
lValve.java:66)
at
ntext.java:102)
at
org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAs
sociationValve.java:158)
at
ntext.java:102)
at
20)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java
:137)
at
ntext.java:104)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java
:118)
at
ntext.java:102)
at
20)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.
java:109)
at
ntext.java:104)
at
20)
at
org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:929)
at
org.apache.coyote.tomcat5.CoyoteAdapter.service(CoyoteAdapter.java:160)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:79
9)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processC
onnection(Http11Protocol.java:705)
at
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:57
7)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool
.java:683)
at java.lang.Thread.run(Thread.java:595)
2008-02-04 12:44:39,266 INFO [jeeves.webapp.main.home] - Returning
search data
2008-02-04 12:44:39,267 ERROR [jeeves.service] - (C) Stack trace is :
at org.fao.geonet.guiservices.keywords.Get.exec(Get.java:55)
at
a:119)
at
va:104)
at
ava:584)
at
8)
at
at
at
at
erChain.java:157)
at
r.java:75)
at
at
erChain.java:157)
at
e.java:214)
at
ntext.java:104)
at
20)
at
textValve.java:198)
at
e.java:152)
at
ntext.java:104)
at
lValve.java:66)
at
ntext.java:102)
at
at
ntext.java:102)
at
20)
at
:137)
at
ntext.java:104)
at
:118)
at
ntext.java:102)
at
20)
at
java:109)
at
ntext.java:104)
at
20)
at
at
at
9)
at
at
7)
at
.java:683)
reconnecting: 21940>=1 ms since last connection
reconnecting: 5>=1 ms since last connection
2008-02-04 12:44:39,293 ERROR [jeeves.service] - Exception executing gui
2008-02-04 12:44:39,293 ERROR [jeeves.service] - (C) Stack trace is :
at org.fao.geonet.guiservices.util.Sources.exec(Sources.java:50)
at
a:119)
at
va:104)
at
ava:584)
at
8)
at
at
at
at
erChain.java:157)
at
r.java:75)
at
at
erChain.java:157)
at
e.java:214)
at
ntext.java:104)
at
20)
at
textValve.java:198)
at
e.java:152)
at
ntext.java:104)
at
lValve.java:66)
at
ntext.java:102)
at
at
ntext.java:102)
at
20)
at
:137)
at
ntext.java:104)
at
:118)
at
ntext.java:102)
at
20)
at
java:109)
at
ntext.java:104)
at
20)
at
at
at
9)
at
at
7)
at
.java:683)
2008-02-04 12:44:39,294 ERROR [jeeves.service] - (C) Stack trace is :
at
org.fao.geonet.guiservices.metadata.GetLatestUpdated.exec(GetLatestUpdat
ed.java:76)
at
a:119)
at
va:104)
at
ava:584)
at
8)
at
at
at
at
erChain.java:157)
at
r.java:75)
at
at
erChain.java:157)
at
e.java:214)
at
ntext.java:104)
at
20)
at
textValve.java:198)
at
e.java:152)
at
ntext.java:104)
at
lValve.java:66)
at
ntext.java:102)
at
at
ntext.java:102)
at
20)
at
:137)
at
ntext.java:104)
at
:118)
at
ntext.java:102)
at
20)
at
java:109)
at
ntext.java:104)
at
20)
at
at
at
9)
at
at
7)
at
.java:683)
2008-02-04 12:44:39,294 ERROR [jeeves.service] - Exception executing gui
at
org.fao.geonet.guiservices.metadata.GetRandom.exec(GetRandom.java:82)
at
a:119)
at
va:104)
at
ava:584)
at
8)
at
at
at
at
erChain.java:157)
at
r.java:75)
at
at
erChain.java:157)
at
e.java:214)
at
ntext.java:104)
at
20)
at
textValve.java:198)
at
e.java:152)
at
ntext.java:104)
at
lValve.java:66)
at
ntext.java:102)
at
at
ntext.java:102)
at
20)
at
:137)
at
ntext.java:104)
at
:118)
at
ntext.java:102)
at
20)
at
java:109)
at
ntext.java:104)
at
20)
at
at
at
9)
at
at
7)
at
.java:683)
2008-02-04 12:44:39,302 INFO [jeeves.service] - -> transforming
with stylesheet :
/usr/local/jboss-3.2.6/server/default/deploy/geonetwork.war/xsl/main-pag
e.xsl
2008-02-04 12:44:39,915 INFO [jeeves.service] - -> end
transformation for : main.home
2008-02-04 12:44:39,915 INFO [jeeves.service] - -> output ended for
: main.home
2008-02-04 12:44:39,915 INFO [jeeves.service] - -> dispatch ended for
: main.home
2008-02-04 12:44:40,944 INFO [jeeves.engine] - === Starting system
2008-02-04 12:44:40,944 INFO [jeeves.engine] - Java version :
1.5.0_11-b03
2008-02-04 12:44:40,944 INFO [jeeves.engine] - Java vendor : Sun
Microsystems Inc.
2008-02-04 12:44:40,945 INFO [jeeves.engine] - XSLT factory :
org.apache.xalan.transformer.TransformerIdentityImpl
2008-02-04 12:44:40,945 INFO [jeeves.engine] - Path :
/usr/local/jboss-3.2.6/server/default/deploy/intermap.war/
2008-02-04 12:44:40,945 INFO [jeeves.engine] - BaseURL : intermap
2008-02-04 12:44:40,945 INFO [jeeves.engine] - Loading :
/usr/local/jboss-3.2.6/server/default/deploy/intermap.war/WEB-INF/config
.xml
2008-02-04 12:44:40,948 INFO [jeeves.engine] - Initializing general
configuration...
2008-02-04 12:44:40,948 INFO [jeeves.engine] - Initializing defaults...
2008-02-04 12:44:40,949 INFO [jeeves.engine] - Default local is
:true
2008-02-04 12:44:40,949 INFO [jeeves.engine] - Initializing
resources...
2008-02-04 12:44:40,949 INFO [jeeves.engine] - Initializing services...
2008-02-04 12:44:40,949 INFO [jeeves.engine] - Adding service :
map.getMain.embedded
mapServers.getServices
mapServers.getServices.embedded
mapServers.getServicesExt
mapServers.getServices.xml
map.addServices
map.addServices.embedded
map.addServicesExt
2008-02-04 12:44:40,950 INFO [jeeves.engine] - Adding service :
mapContexts.get
mapServers.listServers
mapServers.listServers.embedded
mapServers.listServers.xml
map.getLayers.embedded
map.layers.deleteLayer
map.layers.getOrder
2008-02-04 12:44:40,951 INFO [jeeves.engine] - Adding service :
map.layers.setOrder
map.layers.moveUp
map.layers.moveDown
map.layers.setTransparency
map.layers.toggleVisibility
map.action
map.move
map.setScale
map.update
2008-02-04 12:44:40,952 INFO [jeeves.engine] - Adding service :
map.setAoi
map.unsetAoi
map.fullExtent
map.zoomToService
map.reset
map.identify
map.service.getLegend
map.service.wmsConfigForm
map.service.showExtents
map.service.setExtents
2008-02-04 12:44:40,953 INFO [jeeves.engine] - Adding service :
map.service.showError
map.service.wmsLayerInfo
map.refresh
map.getPrintImage
map.setContext
map.getFeatures
wmc.setContext
wmc.setContextFromURL
map.layers.getInspectorData
geonet.getGeonetRecords
map.layers.add
2008-02-04 12:44:40,954 INFO [jeeves.engine] - Adding service :
static.form.pdf
create.pdf
2008-02-04 12:44:40,954 INFO [jeeves.engine] - Initializing
schedules...
2008-02-04 12:44:40,954 INFO [jeeves.engine] - Initializing profiles...
2008-02-04 12:44:40,956 INFO [jeeves.engine] - Found handler :
org.wfp.vam.intermap.Intermap
2008-02-04 12:44:40,956 INFO [jeeves.engine] - --- Starting handler
