Hi List,
I've hit an additional problem with adding directory entries. I can add an
entry using the directory editor, and then re-index it to see the title.
However when I go to edit the entry, the editor box is blank. In chrome dev
tools I see a request to the following
http://localhost:8080/geonetwork/srv/api/records/198/editor?&currTab=simple&starteditingsession=yes&random=0
which results in an error "Root element not set". The entry I'm adding
looks like this:
<gmd:DQ_ConformanceResult xmlns:gmd="http://www.isotc211.org/2005/gmd"
xmlns:gml="http://www.opengis.net/gml/3.2"
xmlns:gts="http://www.isotc211.org/2005/gts"
xmlns:gco="http://www.isotc211.org/2005/gco">
<gmd:specification>
<gmd:CI_Citation>
<gmd:title>
<gmx:Anchor xmlns:gmx="http://www.isotc211.org/2005/gmx"
xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://data.europa.eu/eli/reg/2010/1089">Commission
Regulation (EU) No 1089/2010 of 23 November 2010 implementing Directive
2007/2/EC of the European Parliament and of the Council as regards
interoperability of spatial data sets and services</gmx:Anchor>
</gmd:title>
<gmd:date>
<gmd:CI_Date>
<gmd:date>
<gco:Date xmlns:gco="http://www.isotc211.org/2005/gco
">2010-12-08</gco:Date>
</gmd:date>
<gmd:dateType>
<gmd:CI_DateTypeCode codeList="
http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/codelist/ML_gmxCodelists.xml#CI_DateTypeCode
codeListValue="publication"/>
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
</gmd:CI_Citation>
</gmd:specification>
<!-- Explanation is a required element but can be empty -->
<gmd:explanation xmlns:gco="http://www.isotc211.org/2005/gco"
gco:nilReason="inapplicable"/>
<!-- If not tested then -->
<gmd:pass xmlns:gco="http://www.isotc211.org/2005/gco"
gco:nilReason="unknown">
<gco:Boolean xmlns:gml="http://www.opengis.net/gml/3.2"
xmlns:xlink="http://www.w3.org/1999/xlink"/>
</gmd:pass>
</gmd:DQ_ConformanceResult>
and this is successfully indexed so that the title/anchor shows, but as
mentioned I get the above error when I try to edit it.
Any help would be greatly appreciated.
Jo
On Fri, Sep 6, 2019 at 10:18 AM Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
Should be taken from the proper schema:
https://github.com/geonetwork/core-geonetwork/blob/master/core/src/main/java/org/fao/geonet/kernel/search/SearchManager.java#L686
Usually you need to import in your schema xslt the one from iso19139, like
what is done in GEMINI 2.3:
https://github.com/AstunTechnology/iso19139.gemini23/blob/3.4.x/src/main/plugin/iso19139.gemini23/index-fields/index-subtemplate.xsl#L32
And below defined the new templates or override existing ones from
ISO19139 (probably need to add also higher priority in this case).
With that changes I would expect that works fine.
Jose García
On Fri, Sep 6, 2019 at 11:11 AM Jo Cook <jocook@anonymised.com>
wrote:
Hi Jose,
Thanks- this works a treat. I did have to add the additional xsl to the
index-subtemplate.xsl for ISO19139 rather than my schema, is that because
it's impossible to autodetect which schema an entry belongs to?
Jo
On Fri, Sep 6, 2019 at 5:58 AM Jose Garcia <jose.garcia@anonymised.com>
wrote:
Hi Jo
Directory entries use this xslt for indexing:
https://github.com/geonetwork/core-geonetwork/blob/master/schemas/iso19139/src/main/plugin/iso19139/index-fields/index-subtemplate.xsl
Jose García
On Thu, Sep 5, 2019 at 5:15 PM Jo Cook <jocook@anonymised.com>
wrote:
Hi List,
I'm creating directory entries for INSPIRE conformance results in
Geonetwork 3.4.x and later versions. The entries are created, but no
titles are shown. I can't see anywhere to add titles in the editing
interface but have seen examples where titles are shown. Where do
these derive from? I'm using snippets like this:
xmlns:xlink="http://www.w3.org/1999/xlink">
<gmd:specification>
<gmd:CI_Citation>
<gmd:title>
<gco:CharacterString>Commission Regulation (EU) No
1089/2010 of 23 November 2010 implementing Directive 2007/2/EC of the
European Parliament and of the Council as regards interoperability of
spatial data sets and services</gco:CharacterString>
</gmd:title>
<gmd:date>
<gmd:CI_Date>
<gmd:date>
<gco:Date>2010-12-08</gco:Date>
</gmd:date>
<gmd:dateType>
codeList="
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
</gmd:CI_Citation>
<gmd:explanation>
<gco:CharacterString>See
http://eur-lex.europa.eu/LexUriServ/LexUriServ.do?uri=OJ:L:2010:323:0011:0102:EN:PDF
</gmd:explanation>
<gmd:pass>
<gco:Boolean>true</gco:Boolean>
</gmd:pass>
Thanks
Jo
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
Please note that currently I do not work on Friday afternoons. For
urgent responses at that time, please visit
support.astuntechnology.com or phone our office on 01372 744009
*Sign up to our mailing list
<https://astuntechnology.com/company/#email-updates> for updates on
news,
products, conferences, events and training*
Astun Technology Ltd, The
Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744
009 w: astuntechnology.com <http://astuntechnology.com/
> twitter:@astuntech
<https://twitter.com/astuntech>
iShare - enterprise geographic
intelligence platform <https://astuntechnology.com/ishare/>
GeoServer,
PostGIS and QGIS training <
https://astuntechnology.com/services/#training>
Helpdesk and customer portal
<http://support.astuntechnology.com/support/login>
Company registration
no. 5410695. Registered in England and Wales. Registered office: 120
Manor
Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
*Jo Cook*
Please note that currently I do not work on Friday afternoons. For urgent
responses at that time, please visit support.astuntechnology.com or
<https://astuntechnology.com/company/#email-updates> for updates on news,
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey,
KT18 7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
<https://astuntechnology.com/services/#training>
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
*Jo Cook*
responses at that time, please visit support.astuntechnology.com or phone
t:+44 1372 744
009 w: astuntechnology.com <http://astuntechnology.com/> twitter:@astuntech
GeoServer,
PostGIS and QGIS training <https://astuntechnology.com/services/#training>
no. 5410695. Registered in England and Wales. Registered office: 120 Manor
