[GeoNetwork-users] Disable logrotate/Log4j RollingFileAppender, creating a new log file at midnight while harvesting
Hello, list,
if Geonetwork harvests beyond midnight or 00:00 UTC a new log file is
created. I would like to avoid that, so that logs concerning a harvesting
are in one file. Is it enough to rename from RollingFileAppender to
FileAppender? The file would be
/usr/local/tomcat/webapps/geonetwork/WEB-INF/classes/log4j-dev.xml? If not,
how? :slight_smile:
Kind regards
Gregor
BKG
Hi
I see this code:
https://github.com/geonetwork/core-geonetwork/blob/b0fb96b5b7bd23da5956a99926d559f2a7967225/harvesters/src/main/java/org/fao/geonet/kernel/harvest/harvester/AbstractHarvester.java#L205
DailyRollingFileAppender fa = new DailyRollingFileAppender();
That is creating the log file for the harvester execution, but indeed if
the harvesting ends in the following day, should be creating a new file. As
each harvester log file gets a name that contains the start date of the
harvesting I think using FileAppender should fix the issue, no need to use
any rolling appender.
Can you open an issue in GitHub? A pull request is also welcome if you can
do it,
Thanks and regards,
Jose García
On Thu, Aug 13, 2020 at 4:00 PM Ob Rzwo <obr2pd@anonymised.com> wrote:
Hello, list,
how? :slight_smile:
Kind regards
Gregor
BKG
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
