[GeoNetwork-users] Display problems after upgrade to v3.2.0
I recently migrated our 800-entry catalogue from GN v.3.0.3 to v.3.2.0, but I am having display problems. For the three main display views:
search view - I can see the complete title, abstract, thumbnail and any options (links, download files, map layers)
edit view - I see the simple, full and xml views, but no links or download files
metadata view - default view is present, but without the Download and Links section. The full view is completely blank.
Our database is a PostGIS jndi installation, with GN/GS data file folders separate from the application. During the migration, I had an error message regarding keyvalue already existing in the harvesterdata table, and the installation application recommended a manual database migration, which I did.
I created a separate test h2 database installation, and compared all the entries in the Settings and Status/Information screens, which are exactly the same allowing for a different database and different folder location prefixes.
Is there something obvious I am missing?
Is there a nice way to migrate the records (metadata, thumbnails and data files), so that I can do a clean re-install, if that is the only remaining alternative?
I am hoping that I do not need to individually dump 800+ MEFs. I tried doing batches of 20 or so, but soon hit a memory overflow error (some data files are quite large). Prior to my attempted migration, I cloned the PostGIS database as a backup and copied the GN/GS data folders, but that does not solve my problem if the issue is in the data folders. I also hit a subvention error where my new database name was not exactly the same as the previous installation, and I had to do some renaming.
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
