[GeoNetwork-users] Elastic search version for the latest GN version
could you please tell me which version of elasticsearch you recommend to be used for GN v4.4.0?
I tried using the last one elasticsearch-8.10.3 but I got the following error:
ERROR [geonetwork.index] - Error during querying index. method [POST], host [http://10.8.244.64:9200], URI [/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512], status line [HTTP/1.1 404 Not Found]
Warnings: [[ignore_throttled] parameter is deprecated because frozen indices have been deprecated. Consider cold or frozen tiers in place of frozen indices.]
{"error":{"root_cause":[{"type":"index_not_found_exception","reason":"no such index [gn-records]","resource.type":"index_or_alias","resource.id":"gn-records","index_uuid":"_na_","index"reason":"no such index [gn-records]","resource.type":"index_or_alias","resource.id":"gn-records","index_uuid":"_na_","index":"gn-records"},"status":404}
even if I created the index as indicated in the GN guideline
regards,
Bartolomeo Ventura, PhD
Eurac Research
Institute for Earth Observation
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@anonymised.com<mailto:bartolomeo.ventura@anonymised.com>
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu/&gt;
This transmission is intended only for the use of the addressee and may contain confidential or legally privileged information.
If you receive this transmission by error, please notify the author immediately by mail and delete all copies of this transmission and any attachments.
Any use or dissemination of this communication is strictly prohibited by the "Privacy-Code", D.Lgs. 196/2003 and may lead to penal prosecution and liability for damages.
P Think before you print
Hello,
The actual supported version is the *7.15.1*.
See core-geonetwork/pom.xml at main · geonetwork/core-geonetwork · GitHub
On Tue, Oct 17, 2023 at 3:09 PM Ventura Bartolomeo via GeoNetwork-users <
geonetwork-users@lists.sourceforge.net> wrote:
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
[image: This is Florent Gravin's card. Their email is
florent.gravin@anonymised.com]
<https://hihello.me/p/198272c7-2709-4f8c-8bb0-0b01e91cac7f&gt;
Ciao Bartolomeo,
In our deployment we are currently using 7.17.12. I believe the limitation is 'major version 7'.
Best regards,
Joachim
From: Ventura Bartolomeo via GeoNetwork-users <geonetwork-users@anonymised.comeforge.net>
Sent: Tuesday, 17 October 2023 11:35
To: geonetwork-users@lists.sourceforge.net <geonetwork-users@anonymised.comrge.net>
Subject: [GeoNetwork-users] Elastic search version for the latest GN version
ERROR [geonetwork.index] - Error during querying index. method [POST], host [http://10.8.244.64:9200/&gt;\], URI [/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512], status line [HTTP/1.1 404 Not Found]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.eurac.edu%2F&data=05|01|joachim.nielandt%40vlaanderen.be|f2dafb6642ef4193974b08dbcf135ccf|0c0338a695614ee8b8d64e89cbd520a0|0|0|638331454316042880|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000|||&sdata=%2BxlaRO1HqosKAE1IuuBXe%2FBmrC%2BVEXaelXU6YX%2F8M3Q%3D&reserved=0&lt;http://www.eurac.edu/&gt;
https://eur03.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.sourceforge.net%2Flists%2Flistinfo%2Fgeonetwork-users&data=05|01|joachim.nielandt%40vlaanderen.be|f2dafb6642ef4193974b08dbcf135ccf|0c0338a695614ee8b8d64e89cbd520a0|0|0|638331454316042880|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000|||&sdata=6dB%2B0wyDozeiKnj8dnLCzRadIiJv15divP1QBUsOrLY%3D&reserved=0&lt;https://lists.sourceforge.net/lists/listinfo/geonetwork-users&gt;
GeoNetwork OpenSource is maintained at https://eur03.safelinks.protection.outlook.com/?url=http%3A%2F%2Fsourceforge.net%2Fprojects%2Fgeonetwork&data=05|01|joachim.nielandt%40vlaanderen.be|f2dafb6642ef4193974b08dbcf135ccf|0c0338a695614ee8b8d64e89cbd520a0|0|0|638331454316042880|Unknown|TWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D|3000|||&sdata=UWFwmGiectQXCd%2F%2F5KeXpRJClcTxVsNCptCRajWWtN8%3D&reserved=0&lt;http://sourceforge.net/projects/geonetwork&gt;
I installed the version 7.15.1 but even if it is up and running I'm getting the following error
ERROR [geonetwork.index] - Error during index creation. Error is: Could not connect to index 'gn-records'. Error is Compressor detection can only be called on some xcontent bytes or compressed xcontent bytes. Is the index server up and running?
Elasticsearch is up and running
If I create via curl the gn-index
curl -X PUT "10.8.244.64:9200/gn-records" -H 'Content-Type: application/json'
it seems working but if I create a metadata and I search for it the same error appears again
Any suggestions?
thanks
Sent: Tuesday, October 17, 2023 15:20
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...>
Cc: geonetwork-users@lists.sourceforge.net <geonetwork-users@lists.sourceforge.net>
Subject: Re: [GeoNetwork-users] Elastic search version for the latest GN version
You don't often get email from florent.gravin@...1966... Learn why this is important<https://aka.ms/LearnAboutSenderIdentification&gt;
Hello,
The actual supported version is the 7.15.1.
See https://github.com/geonetwork/core-geonetwork/blob/main/pom.xml#L1524
On Tue, Oct 17, 2023 at 3:09 PM Ventura Bartolomeo via GeoNetwork-users <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>> wrote:
{"error":{"root_cause":[{"type":"index_not_found_exception","reason":"no such index [gn-records]","resource.type":"index_or_alias","resource.id<http://resource.id/&gt;&quot;:&quot;gn\-records&quot;,&quot;index\_uuid&quot;:&quot;\_na\_&quot;,&quot;index&quot;reason&quot;:&quot;no such index [gn-records]","resource.type":"index_or_alias","resource.id<http://resource.id/&gt;&quot;:&quot;gn\-records&quot;,&quot;index\_uuid&quot;:&quot;\_na\_&quot;,&quot;index&quot;:&quot;gn\-records&quot;\},"status":404}
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…><mailto:bartolomeo.ventura@…1518…>
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu/&gt;&lt;http://www.eurac.edu/&gt;
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
[This is Florent Gravin's card. Their email is florent.gravin@...1966...]<https://hihello.me/p/198272c7-2709-4f8c-8bb0-0b01e91cac7f&gt;
Hello,
I would follow the instructions right there:
You may need to *delete* your index first, and recreate it.
Let us know if it helps.
On Wed, Oct 18, 2023 at 2:49 PM Ventura Bartolomeo <
bartolomeo.ventura@anonymised.com> wrote:
*ERROR [geonetwork.index] - Error during index creation. Error is: Could
server up and running?*
*curl -X PUT "10.8.244.64:9200/gn-records
<http://10.8.244.64:9200/gn-records&gt;&quot; -H 'Content-Type: application/json'*
error appears again
Any suggestions?
thanks
*From:* Florent Gravin <florent.gravin@anonymised.com>
*Sent:* Tuesday, October 17, 2023 15:20
*To:* Ventura Bartolomeo <bartolomeo.ventura@anonymised.com>
*Cc:* geonetwork-users@lists.sourceforge.net <
*Subject:* Re: [GeoNetwork-users] Elastic search version for the latest
GN version
You don't often get email from florent.gravin@anonymised.com Learn why
this is important <Bing;
Hello,
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
unfortunately it did not help.
I deleted the index and created them again. But as soon as I try to add a metadata the same error message returns.
I tried to delete and reindex via GN but it did not help too
the error in this case is
[gn-records] ElasticsearchStatusException[Elasticsearch exception [type=index_not_found_exception, reason=no such index [gn-records]]]
[cid:e548cdec-5d40-41f3-ab6a-ea17e573cfdf]
Sent: Wednesday, October 18, 2023 14:52
Hello,
I would follow the instructions right there: https://github.com/geonetwork/core-geonetwork/tree/main/es#configuration
You may need to delete your index first, and recreate it.
On Wed, Oct 18, 2023 at 2:49 PM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
curl -X PUT "10.8.244.64:9200/gn-records<http://10.8.244.64:9200/gn-records&gt;&quot; -H 'Content-Type: application/json'
Any suggestions?
thanks
From: Florent Gravin <florent.gravin@...137...<mailto:florent.gravin@…137…>>
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>>
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net> <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>>
You don't often get email from florent.gravin@...137...<mailto:florent.gravin@…137…>. Learn why this is important<https://aka.ms/LearnAboutSenderIdentification&gt;
Hello,
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
(attachments)
Hmm,
If you are sure that you've created the gn-records index on
*10.8.244.64:9200/gn-records
<http://10.8.244.64:9200/gn-records&gt;\* and not on *localhost:9200*, and that
you are sure that your GeoNetwork points to the ES on *10.8.244.64:9200
<http://10.8.244.64:9200>*/gn-records, then yes, I don't see why it
complains about not finding the gn-records index.
Could you double check that:
   - you have created the index on the correct instance
   - you have set up the correct ES path in GeoNetwork
   - GeoNetwork web app can reach your ES in terms of network
On Wed, Oct 18, 2023 at 3:26 PM Ventura Bartolomeo <
*Sent:* Wednesday, October 18, 2023 14:52
GN version
Hello,
core-geonetwork/es at main · geonetwork/core-geonetwork · GitHub
error appears again
Any suggestions?
thanks
GN version
Hello,
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
!image.png|1169x545
  * you have created the index on the correct instance
these are the commands I used:
IDX_PREFIX=gn
curl -X DELETE http://10.8.244.64:9200/$IDX_PREFIX-searchlogs
curl -X DELETE http://10.8.244.64:9200/$IDX_PREFIX-records
curl -X DELETE http://10.8.244.64:9200/$IDX_PREFIX-features
curl -X PUT http://10.8.244.64:9200/$IDX_PREFIX-records -H "Content-Type:application/json" -d @../apps/geonetwork/WEB-INF/data/config/index/records.json
curl -X PUT http://10.8.244.64:9200/$IDX_PREFIX-features -H "Content-Type:application/json" -d @../apps/geonetwork/WEB-INF/data/config/index/features.json
curl -X PUT http://10.8.244.64:9200/$IDX_PREFIX-searchlogs -H "Content-Type:application/json" -d @../apps/geonetwork/WEB-INF/data/config/index/searchlogs.json
  * you have set up the correct ES path in GeoNetwork
this is the section extracted from the /opt/geonetwork/apps/geonetwork/WEB-INF/config.properties file
language.default=eng
language.forceDefault=true
# Define using CRON expression when watchlist notifier is triggered (Default 4AM)
usersavedselection.watchlist.frequency=0 0 4 * * ?
# Define the link to the list of updated records sent by email by the watchlist notifier
usersavedselection.watchlist.searchurl=catalog.search#/search?_uuid={{filter}}
# Define the link to each record sent by email by the watchlist notifier
usersavedselection.watchlist.recordurl=api/records/{{index:uuid}}
es.protocol=http
es.port=9200
es.host=10.8.244.64
es.url=${es.protocol}://${es.host}:${es.port}
es.username=
es.password=
es.index.features=gn-features
es.index.features.type=features
Is it enough or should I check somewhere else?
  * GeoNetwork web app can reach your ES in terms of network
Elasticsearch is installed on the same VM. To be sure Is there a specific way to check it?
thanks!
Sent: Wednesday, October 18, 2023 15:41
Hmm,
If you are sure that you've created the gn-records index on 10.8.244.64:9200/gn-records<http://10.8.244.64:9200/gn-records&gt; and not on localhost:9200, and that you are sure that your GeoNetwork points to the ES on 10.8.244.64:9200<http://10.8.244.64:9200/&gt;/gn\-records, then yes, I don't see why it complains about not finding the gn-records index.
On Wed, Oct 18, 2023 at 3:26 PM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
[/uploads/default/original/2X/4/416f21fd5eaa83f626db6da47473bf727732850a.png]
Hello,
Any suggestions?
thanks
Hello,
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
Ok, everything looks good, you can confirm the ES config from the admin
console: admin.console#/dashboard/information (at the bottom)
On Wed, Oct 18, 2023 at 4:05 PM Ventura Bartolomeo <
*IDX_PREFIX=gn*
*curl -X DELETE http://10.8.244.64:9200/$IDX_PREFIX-searchlogs
<http://10.8.244.64:9200/$IDX_PREFIX-searchlogs&gt;\*
*curl -X DELETE http://10.8.244.64:9200/$IDX_PREFIX-records
<http://10.8.244.64:9200/$IDX_PREFIX-records&gt;\*
*curl -X DELETE http://10.8.244.64:9200/$IDX_PREFIX-features
<http://10.8.244.64:9200/$IDX_PREFIX-features&gt;\*
* curl -X PUT http://10.8.244.64:9200/$IDX_PREFIX-records
<http://10.8.244.64:9200/$IDX_PREFIX-records&gt; -H
@../apps/geonetwork/WEB-INF/data/config/index/records.json*
*curl -X PUT http://10.8.244.64:9200/$IDX_PREFIX-features
<http://10.8.244.64:9200/$IDX_PREFIX-features&gt; -H
@../apps/geonetwork/WEB-INF/data/config/index/features.json*
*curl -X PUT http://10.8.244.64:9200/$IDX_PREFIX-searchlogs
<http://10.8.244.64:9200/$IDX_PREFIX-searchlogs&gt; -H
@../apps/geonetwork/WEB-INF/data/config/index/searchlogs.json*
l*anguage.default=eng*
*language.forceDefault=true*
*# Define using CRON expression when watchlist notifier is triggered
(Default 4AM)*
*usersavedselection.watchlist.frequency=0 0 4 * * ?*
*# Define the link to the list of updated records sent by email by the
watchlist notifier*
*usersavedselection.watchlist.searchurl=catalog.search#/search?_uuid={{filter}}*
*# Define the link to each record sent by email by the watchlist notifier*
*usersavedselection.watchlist.recordurl=api/records/{{index:uuid}}*
*es.protocol=http*
*es.port=9200*
*es.host=10.8.244.64*
*es.url=${es.protocol}://${es.host}:${es.port}*
*es.username=*
*es.password=*
*es.index.features=gn-features*
*es.index.features.type=features*
way to check it?
thanks!
*Sent:* Wednesday, October 18, 2023 15:41
GN version
Hmm,
If you are sure that you've created the gn-records index on *10.8.244.64:9200/gn-records
that you are sure that your GeoNetwork points to the ES on *10.8.244.64:9200
<http://10.8.244.64:9200/&gt;\*/gn\-records, then yes, I don't see why it
GN version
Hello,
error appears again
Any suggestions?
thanks
GN version
Hello,
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
!image.png|1169x545
elasticsearch seems to be there as you can see in the following figure where the gn-records index seems to be present too
[cid:ad4edb88-ee97-4adf-bff8-c385e3f4be2b]
Might it be an error related to the DB?
thanks!
Sent: Wednesday, October 18, 2023 17:06
Ok, everything looks good, you can confirm the ES config from the admin console: admin.console#/dashboard/information (at the bottom)
On Wed, Oct 18, 2023 at 4:05 PM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
IDX_PREFIX=gn
es.protocol=http
es.port=9200
es.host=10.8.244.64
es.username=
es.password=
thanks!
Hmm,
Hello,
Any suggestions?
thanks
Hello,
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
(attachments)
frozen indices.]
Well, the logs indicate that
   - GeoNetwork actually fetches ES on http://10.8.244.64:9200 (which is
   correct)
   - The index is not found
   - It seems that ES is answering something though, so would mean that GN
   can talk to ES, but the gn-records index is not found (it's just a guess
   from the logs).
Does this request returns something ?
http://10.8.244.64:9200/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512
I don't think it's related to the DB, but to the ability of GN to reach ES
or that ES does not have a gn-records index.
I am not too much of an infra guy so maybe people in the ML who are more
comfortable with setting GeoNetwork up could give some hints.
On Thu, Oct 19, 2023 at 8:21 AM Ventura Bartolomeo <
thanks!
*Sent:* Wednesday, October 18, 2023 17:06
GN version
*IDX_PREFIX=gn*
(Default 4AM)*
watchlist notifier*
*es.protocol=http*
*es.port=9200*
*es.username=*
*es.password=*
way to check it?
thanks!
GN version
Hmm,
GN version
Hello,
error appears again
Any suggestions?
thanks
GN version
Hello,
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
!image.png|1169x545
!image.png|1142x898
this is what I get from the request:
  "error": {
    "root_cause": [
        "type": "illegal_argument_exception",
        "reason": "request [/gn-records/_search] contains unrecognized parameter: [max_concurrent_shards]"
  "status": 400
regards,
Sent: Thursday, October 19, 2023 08:35
ERROR [geonetwork.index] - Error during querying index. method [POST], host [http://10.8.244.64:9200/&gt;&lt;http://10.8.244.64:9200/&gt;\], URI [/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512], status line [HTTP/1.1 404 Not Found]
  * GeoNetwork actually fetches ES on http://10.8.244.64:9200/&gt; (which is correct)
  * The index is not found
  * It seems that ES is answering something though, so would mean that GN can talk to ES, but the gn-records index is not found (it's just a guess from the logs).
Does this request returns something ? http://10.8.244.64:9200/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512
I don't think it's related to the DB, but to the ability of GN to reach ES or that ES does not have a gn-records index.
I am not too much of an infra guy so maybe people in the ML who are more comfortable with setting GeoNetwork up could give some hints.
On Thu, Oct 19, 2023 at 8:21 AM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
[/uploads/default/original/2X/d/d0e69ee0c1fbe141494832d90483daf88c28a51a.png]
thanks!
IDX_PREFIX=gn
es.protocol=http
es.port=9200
es.host=10.8.244.64
es.username=
es.password=
thanks!
Hmm,
Hello,
Any suggestions?
thanks
Hello,
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
Then remove the parameter max_concurrent_shards from the request, does it
work ?
On Thu, Oct 19, 2023 at 8:38 AM Ventura Bartolomeo <
  "error": {
    "root_cause": [
  "status": 400
regards,
*Sent:* Thursday, October 19, 2023 08:35
GN version
frozen indices.]
   correct)
   from the logs).
thanks!
GN version
*IDX_PREFIX=gn*
(Default 4AM)*
watchlist notifier*
*es.protocol=http*
*es.port=9200*
*es.username=*
*es.password=*
way to check it?
thanks!
GN version
Hmm,
GN version
Hello,
error appears again
Any suggestions?
thanks
GN version
Hello,
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
!image.png|1169x545
!image.png|1142x898
Well I tried but perhaps I was not doing in the correct way
could you please tell me how to remove that parameter?
thanks
Sent: Thursday, October 19, 2023 08:39
Then remove the parameter max_concurrent_shards from the request, does it work ?
On Thu, Oct 19, 2023 at 8:38 AM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
  "error": {
    "root_cause": [
  "status": 400
regards,
thanks!
IDX_PREFIX=gn
es.protocol=http
es.port=9200
es.host=10.8.244.64
es.username=
es.password=
thanks!
Hmm,
Hello,
Any suggestions?
thanks
Hello,
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
Take the url http://10.8.244.64:9200/gn-records/_search?typed_keys=true
*&max_concurrent_shards=open*
<http://10.8.244.64:9200/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512&gt;
and remove the bold statement.
On Thu, Oct 19, 2023 at 8:44 AM Ventura Bartolomeo <
thanks
*Sent:* Thursday, October 19, 2023 08:39
GN version
work ?
  "error": {
    "root_cause": [
  "status": 400
regards,
GN version
frozen indices.]
   correct)
   from the logs).
thanks!
GN version
*IDX_PREFIX=gn*
(Default 4AM)*
watchlist notifier*
*es.protocol=http*
*es.port=9200*
*es.username=*
*es.password=*
way to check it?
thanks!
GN version
Hmm,
GN version
Hello,
error appears again
Any suggestions?
thanks
GN version
Hello,
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
!image.png|1169x545
!image.png|1142x898
You can check the existing indexes with this request:
curl https://elascticsearch-host:9200/_cat/indices
If the gn-records index is there you can check the details calling
curl https://elascticsearch-host:9200/_cat/indices/gn-records
If you can try them from the GN host to check if there is any connectivity problem between ES and GN.
Best regards,
Juan Luis.
https://www.geocat.net
Juan Luis Rodriguez Ponce
E-mail: juanluisrp@anonymised.com
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Thu, 19 Oct 2023 08:39:35 +0200 Florent Gravin via GeoNetwork-users <geonetwork-users@lists.sourceforge.net> wrote ---
work ?
mailto:bartolomeo.ventura@anonymised.com> wrote:
  "error": {
    "root_cause": [
  "status": 400
regards,
*From:* Florent Gravin <mailto:florent.gravin@anonymised.com>
*To:* Ventura Bartolomeo <mailto:bartolomeo.ventura@anonymised.com>
*Cc:* mailto:geonetwork-users@lists.sourceforge.net <
GN version
host [http://10.8.244.64:9200&lt;http://10.8.244.64:9200/&amp;gt;\], URI
frozen indices.]
   correct)
   from the logs).
thanks!
GN version
*IDX_PREFIX=gn*
<http://10.8.244.64:9200/$IDX_PREFIX-searchlogs&gt;*
<http://10.8.244.64:9200/$IDX_PREFIX-records&gt;*
<http://10.8.244.64:9200/$IDX_PREFIX-features&gt;*
(Default 4AM)*
watchlist notifier*
*es.protocol=http*
*es.port=9200*
*es.username=*
*es.password=*
way to check it?
thanks!
GN version
Hmm,
<http://10.8.244.64:9200/gn-records&gt;* and not on *localhost:9200*, and
<http://10.8.244.64:9200/&gt;*/gn-records, then yes, I don't see why it
GN version
You don't often get email from mailto:florent.gravin@anonymised.com Learn why
this is important <https://aka.ms/LearnAboutSenderIdentification&gt;
Hello,
error appears again
Any suggestions?
thanks
GN version
Hello,
mailto:geonetwork-users@lists.sourceforge.net> wrote:
error:
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
mailto:bartolomeo.ventura@anonymised.com<mailto:mailto:bartolomeo.ventura@anonymised.com1518...>
Viale Druso 1
I-39100 Bolzano
attachments.
mailto:florent.gravin@anonymised.com]
I was doing the same and the error is this now
  "error": {
    "root_cause": [
        "type": "index_not_found_exception",
        "reason": "no such index [gn-records]",
        "resource.type": "index_or_alias",
        "resource.id": "gn-records",
        "index_uuid": "_na_",
        "index": "gn-records"
  "status": 404
Sent: Thursday, October 19, 2023 08:45
Take the url http://10.8.244.64:9200/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512&gt;&amp;max\_concurrent\_shards=open&lt;http://10.8.244.64:9200/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512&gt;&amp;allow\_no\_indices=true&amp;ignore\_throttled=true&amp;search\_type=query\_then\_fetch&amp;batched\_reduce\_size=512&lt;http://10.8.244.64:9200/gn-records/_search?typed_keys=true&max_concurrent_shards=open&allow_no_indices=true&ignore_throttled=true&search_type=query_then_fetch&batched_reduce_size=512&gt;
On Thu, Oct 19, 2023 at 8:44 AM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
thanks
  "error": {
    "root_cause": [
  "status": 400
regards,
thanks!
IDX_PREFIX=gn
es.protocol=http
es.port=9200
es.host=10.8.244.64
es.username=
es.password=
thanks!
Hmm,
Hello,
Any suggestions?
thanks
Hello,
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
this is wat I get
curl http://10.8.244.64:9200/_cat/indices
green open .geoip_databases K3TvrTkGQDCJXSMSiGZgnQ 1 0 42 0 40.6mb 40.6mb
yellow open features zef2zMOOSteO7lqH0mtBpw 1 1 0 0 208b 208b
yellow open searchlogs j3SK2Y3OQw2yeWH12P8RwA 1 1 0 0 208b 208b
yellow open gn-searchlogs VvDwV60RQ1WaEg4sMhUOJQ 1 1 0 0 208b 208b
the index is not there and as a consequence
curl http://10.8.244.64:9200/_cat/indices/gn-records
{"error":{"root_cause":[{"type":"index_not_found_exception","reason":"no such index [gn-records]","resource.type":"index_or_alias","resource.id":"gn-records","index_uuid":"_na_","index":"gn-records"}],"type":"index_not_found_exception","reason":"no such index [gn-records]","resource.type":"index_or_alias","resource.id":"gn-records","index_uuid":"_na_","index":"gn-records"},"status":404}
Bartolomeo
From: Juan Luis Rodriguez Ponce <juanluisrp@...444...>
Sent: Thursday, October 19, 2023 08:47
To: Florent Gravin <florent.gravin@...137...>
Cc: Florent Gravin via GeoNetwork-users <geonetwork-users@lists.sourceforge.net>; Ventura Bartolomeo <bartolomeo.ventura@...1518...>
Best regards,
Juan Luis.
[https://www.geocat.net/wp-content/uploads/2022/08/Logo-Colour_w250.png\]<https://www.geocat.net/&gt;
E-mail: juanluisrp@...444...
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
[https://www.geocat.net/wp-content/uploads/2022/08/NRK-logo_Vrienden_van_EN_ON_WHITE_237x150px.png\]
work ?
"error": {
"root_cause": [
"status": 400
regards,
*From:* Florent Gravin <florent.gravin@...137...<mailto:florent.gravin@…137…>>
*To:* Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>>
*Cc:* geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net> <
GN version
host [[http://10.8.244.64:9200&]http://10.8.244.64:9200&lt;http://10.8.244.64:9200/&amp;gt;\], URI
frozen indices.]
- GeoNetwork actually fetches ES on http://10.8.244.64:9200/&gt; (which is
correct)
from the logs).
thanks!
GN version
*IDX_PREFIX=gn*
(Default 4AM)*
watchlist notifier*
*es.protocol=http*
*es.port=9200*
*es.username=*
*es.password=*
way to check it?
thanks!
GN version
Hmm,
GN version
Hello,
error appears again
Any suggestions?
thanks
GN version
Hello,
error:
host [[http://10.8.244.64:9200],]http://10.8.244.64:9200], URI
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
attachments.
florent.gravin@...137...<mailto:florent.gravin@…137…>.]
Then you don't have gn-records index =)
Also you might got some issues with the ENV IDX_PREFIX
Just put the correct name in the url directly eg.
<http://10.8.244.64:9200/$IDX_PREFIX-records&gt;\*gn\-records\* -H
and check that this request succeed
On Thu, Oct 19, 2023 at 8:50 AM Ventura Bartolomeo <
this is wat I get
*curl http://10.8.244.64:9200/_cat/indices
<http://10.8.244.64:9200/_cat/indices&gt;\*
*green open .geoip_databases K3TvrTkGQDCJXSMSiGZgnQ 1 0 42 0 40.6mb
40.6mb*
*yellow open features zef2zMOOSteO7lqH0mtBpw 1 1 0 0 208b
208b*
*yellow open searchlogs j3SK2Y3OQw2yeWH12P8RwA 1 1 0 0 208b
208b*
*yellow open gn-searchlogs VvDwV60RQ1WaEg4sMhUOJQ 1 1 0 0 208b
208b*
*curl http://10.8.244.64:9200/_cat/indices/gn-records
<http://10.8.244.64:9200/_cat/indices/gn-records&gt;
<http://resource.id>":"gn-records","index_uuid":"_na_","index":"gn-records"}],"type":"index_not_found_exception","reason":"no
<http://resource.id>":"gn-records","index_uuid":"_na_","index":"gn-records"},"status":404}*
Bartolomeo
*From:* Juan Luis Rodriguez Ponce <juanluisrp@anonymised.com>
*Sent:* Thursday, October 19, 2023 08:47
*To:* Florent Gravin <florent.gravin@anonymised.com>
*Cc:* Florent Gravin via GeoNetwork-users <
GN version
Best regards,
Juan Luis.
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Thu, 19 Oct 2023 08:39:35 +0200 *Florent Gravin via
<geonetwork-users@lists.sourceforge.net>>* wrote ---
work ?
> Hi,
> "error": {
> "root_cause": [
> "status": 400
> regards,
> GN version
> frozen indices.]
> correct)
guess
> from the logs).
ES
> Hi,
> thanks!
> GN version
> Hi,
> *IDX_PREFIX=gn*
> (Default 4AM)*
> watchlist notifier*
notifier*
> *es.protocol=http*
> *es.port=9200*
> *es.username=*
> *es.password=*
> way to check it?
> thanks!
> GN version
> Hmm,
and
10.8.244.64:9200
> Hi,
> GN version
> Hello,
> Hi all,
index
application/json'*
> error appears again
> Any suggestions?
> thanks
> GN version
> Hello,
> See
> Hi all,
> error:
> frozen indices.]
> regards,
> Eurac Research
> T +39 0471 055 374
> F +39 0471 055 389
> Viale Druso 1
> I-39100 Bolzano
> attachments.
yes, unfortunately, no gn-records index exists :slightly_smiling_face:
curl -X PUT http://10.8.244.64:9200/gn-records -H "Content-Type:application/json" -d @../apps/geonetwork/WEB-INF/data/config/index/records.json
Warning: Couldn't read data from file
Warning: "../apps/geonetwork/WEB-INF/data/config/index/records.json", this
Warning: makes an empty POST.
this is the output of the cmd
regards,
Bartolomeo
Sent: Thursday, October 19, 2023 08:54
Cc: Juan Luis Rodriguez Ponce <juanluisrp@...444...>; Florent Gravin via GeoNetwork-users <geonetwork-users@lists.sourceforge.net>
curl -X PUT http://10.8.244.64:9200/$IDX_PREFIX-records&gt;gn\-records -H "Content-Type:application/json" -d @../apps/geonetwork/WEB-INF/data/config/index/records.json
On Thu, Oct 19, 2023 at 8:50 AM Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>> wrote:
this is wat I get
{"error":{"root_cause":[{"type":"index_not_found_exception","reason":"no such index [gn-records]","resource.type":"index_or_alias","resource.id<http://resource.id/&gt;&quot;:&quot;gn\-records&quot;,&quot;index\_uuid&quot;:&quot;\_na\_&quot;,&quot;index&quot;:&quot;gn\-records&quot;\}],"type":"index_not_found_exception","reason":"no such index [gn-records]","resource.type":"index_or_alias","resource.id<http://resource.id/&gt;&quot;:&quot;gn\-records&quot;,&quot;index\_uuid&quot;:&quot;\_na\_&quot;,&quot;index&quot;:&quot;gn\-records&quot;\},"status":404}
Bartolomeo
From: Juan Luis Rodriguez Ponce <juanluisrp@...444...<mailto:juanluisrp@…444…>>
To: Florent Gravin <florent.gravin@...137...<mailto:florent.gravin@…137…>>
Cc: Florent Gravin via GeoNetwork-users <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>>; Ventura Bartolomeo <bartolomeo.ventura@...1518...<mailto:bartolomeo.ventura@…1518…>>
Best regards,
Juan Luis.
E-mail: juanluisrp@...444...<mailto:juanluisrp@…444…>
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31318416664
---- On Thu, 19 Oct 2023 08:39:35 +0200 Florent Gravin via GeoNetwork-users <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>> wrote ---
work ?
"error": {
"root_cause": [
"status": 400
regards,
GN version
frozen indices.]
correct)
from the logs).
thanks!
GN version
*IDX_PREFIX=gn*
(Default 4AM)*
watchlist notifier*
*es.protocol=http*
*es.port=9200*
*es.username=*
*es.password=*
way to check it?
thanks!
GN version
Hmm,
If you are sure that you've created the gn-records index on *10.8.244.64:9200/gn-records<http://10.8.244.64:9200/gn-records&gt;
that you are sure that your GeoNetwork points to the ES on *10.8.244.64:9200<http://10.8.244.64:9200/&gt;
GN version
Hello,
*curl -X PUT "10.8.244.64:9200/gn-records<http://10.8.244.64:9200/gn-records&gt;
error appears again
Any suggestions?
thanks
GN version
Hello,
error:
host [[http://10.8.244.64:9200/&gt;\],]http://10.8.244.64:9200/&gt;\], URI
frozen indices.]
regards,
Eurac Research
T +39 0471 055 374
F +39 0471 055 389
Viale Druso 1
I-39100 Bolzano
www.eurac.edu<http://www.eurac.edu/&gt;&lt;http://www.eurac.edu/&amp;gt;
attachments.
