Hello,
I'm from the Karst Research Institute ZRC SAZU in Slovenia, which is the
leading partner of LifeWatch Slovenia consortium.
We're using GeoNetwork to publish geographic metadata, but we're interested
in using the EML-GBIF schema for biodiversity data as well.
We're using GN version 4 built from source.
https://metadata.izrk.zrc-sazu.si/
We found the EML schema metadata plugin for GeoNetwork on GitHub, but
unfortunatelly it has stopped being maintained after GeoNetwork 2.
https://github.com/geonetwork/schema-plugins/tree/develop/eml-gbif
Is any work being done on porting the EML-GBIF metadata plugin to
GeoNetwork 4? If not, can you point us in the right direction - to the
right person who could be able to help us with this issue?
Žan
*Žan Kafol <zan@anonymised.com>*, mag. inž. rač. inf · *consultant * · IZRK ZRC
SAZU <https://izrkp.zrc-sazu.si/en> · Karst Research Institute. ·
zan@anonymised.com
