[GeoNetwork-users] Enlarge mapSearch
Hi !
What do I have to do to enlarge the mapSearch in v.2.6.1 ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Enlarge-mapSearch-tp5891500p5891500.html
... I think my post was not clear :slight_smile:
I would like to make the size of the mapSearch window (minimap) bigger. It
is 210px wide by default.
I have found parameters that seemed promising to change in ol_minimap.js but
it has no effect. Is this file obsolete ?
Is there a place I can change the width and height of the mapSearch ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Enlarge-mapSearch-tp5891500p5899248.html
Hi Timothee
You have to change the size in ol_minimap.js, but GeoNetwork uses minified
javascript files.
To change it you need to download the source code, modify ol_minimap.js and
execute mvn install in ROOT_SRC/web folder. You'll get in the folder
ROOT_SRC/web/src/main/webapp/scripts/lib the minified files to copy in the
analogue folder of your GeoNetwork installation.
To test first the change to ol_minimap.js you can use the GeoNetwork
installation, adding &debug=true parameter to URL. With this parameter
GeoNetwork uses the no minified version of javascript files.
I'll check for a next version to put the minimap size in config-gui.xml
file, so should be easy to change.
Jose GarcĂ­a
On Fri, Jan 7, 2011 at 2:57 PM, timothee.becker
but
Gaining the trust of online customers is vital for the success of any
company
that requires sensitive data to be transmitted over the Web. Learn how to
best implement a security strategy that keeps consumers' information secure
and instills the confidence they need to proceed with transactions.
http://p.sf.net/sfu/oracle-sfdevnl
GeoNetwork-users mailing list
Great, thanks !
However, &debug=true doesn't work for me. I found another post with the same
advice except that the additional parameter was ?debug
This works for me in 2.6.1
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Enlarge-mapSearch-tp5891500p5899436.html
