[GeoNetwork-users] Error on page when starting GeoNetwork 2.1
After first running GAST to configure the database (McKoi) and loading test data, I start the Jetty server and then GeoNetwork 2.1 user interface from an IE 6 browser, I get the following error on page...
  Line: 216
  Char: 39
  Error: Expected identifier, string or number
  Code: 0
  URL: http://localhost:8080/geonetwork/srv/en/main.home
Is this a bug, or is some other configuration necessary?
Any help would be appreciated.
Geoffi
Hi Geoffi,
Does it work on Firefox?
Did you try to use http://127.0.0.1:8080/geonetwork ?
Any problems in the logs under ../jetty/log/ ?
Ciao,
Jeroen
On Dec 10, 2007, at 5:48 AM, Geoff Innes wrote:
  Line: 216
  Char: 39
  Code: 0
Geoffi
SF.Net email is sponsored by:
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Hi Jeroen,
No change to the results when I tried IE6 but replacing localhost with the
IP address 127.0.0.1.
FireFox does not appear to produce errors, but examining the Error Console
shows the following warning messages:
Warning: Error in parsing value for property 'cursor'. Declaration dropped.
Source File: http://localhost:8085/geonetwork/geonetwork.css
Line: 148
Line: 216
Line: 226
Line: 288
Warning: Unknown property 'filter'. Declaration dropped.
Source File: http://localhost:8085/intermap/intermap-embedded.css?
Line: 593
Line: 594
Warning: Unknown property '-khtml-opacity'. Declaration dropped.
Line: 597
Line: 687
Warning: Unknown property 'align'. Declaration dropped.
Source File: http://localhost:8085/geonetwork/srv/en/main.home
Line: 0
Line: 0
This last warning is repeated 22 times!
NOTE:
The first warnings relate to the file:
  c:\Program Files\GeoNetwork\web\geonetwork\geonetwork.css
containing the line:
  cursor: hand;
The second set of warning refer to the file:
  c:\Program Files\GeoNetwork\web\internap\intermap-embedded.css?
   line 593> filter:alpha (opacity=50); /* MS Internet Explorer */
   line 594> filter:progid:DXImageTransform.Microsoft.Alpha (style=0,
opacity=50); /* MS IE proprietory */
   line 597> -khtml-opacity:.5; /* Safari */
   line 687> filter: alpha(opacity=50);
There are 2 log files in the ..\jetty\log directory:
jeeves.log Contains INFO and DEBUG lines, but nothing untoward.
date.request.log Contains GET statements.
Does this help you?
Cheers...
Geoff
Jeroen Ticheler-3 wrote:
Hi Geoffi,
Ciao,
Jeroen
page...
  Line: 216
  Char: 39
  Code: 0
Geoffi
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
for just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
View this message in context: http://www.nabble.com/Error-on-page-when-starting-GeoNetwork-2.1-tp14247302s18419p14427433.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Jeroen, Geoffi,
I too was much annoyed by this error message, and got tired of saying "I
don't know, just ignore it," when people asked me about it. So after much
digging and prodding I finally found the source of the problem and a
solution.
The problem lies in the file gn_search.js line 215 -
var closer = Builder.node('div', {class: "im_wbcloser"});
"class" is incorrect. It should be "Class:" (upper case C) or "id:". These
are references to the stylesheet intermap-embedded.css which has both a
class and id entry for im_wbcloser and both entries are identical.
Change this line to : var closer = Builder.node('div', {Class:
"im_wbcloser"}); or
var closer = Builder.node('div', {id: "im_wbcloser"});
and the error message goes away.
Please let me know if you find any problems with this solution.
Byron
geoffi wrote:
Hi Jeroen,
dropped.
Line: 148
dropped.
Line: 216
dropped.
Line: 226
dropped.
Line: 288
Line: 593
Line: 594
Line: 597
Line: 687
Line: 0
dropped.
Line: 0
NOTE:
  cursor: hand;
Does this help you?
Cheers...
Geoff
Hi Geoffi,
Ciao,
Jeroen
page...
  Line: 216
  Char: 39
  Code: 0
Geoffi
projects/geonetwork
View this message in context: http://www.nabble.com/Error-on-page-when-starting-GeoNetwork-2.1-tp14247302s18419p14726498.html
Hi Byron,
Thanks! From what I see, this fix has been applied to the most recent code, so should be available in the RC0 release I will work on today.
Geoffi, the warnings in Firefox are correct indeed. They are warnings for issues that relate to IE 5 and Safari browser compatibility and as such do no harm.
Ciao,
Jeroen
On Jan 10, 2008, at 3:35 AM, ByronC wrote:
Hi Jeroen, Geoffi,
solution.
"im_wbcloser"}); or
Byron
geoffi wrote:
Hi Jeroen,
dropped.
Line: 148
dropped.
Line: 216
dropped.
Line: 226
dropped.
Line: 288
Line: 593
Line: 594
Line: 597
Line: 687
Line: 0
dropped.
Line: 0
NOTE:
  cursor: hand;
Does this help you?
Cheers...
Geoff
Hi Geoffi,
Ciao,
Jeroen
page...
  Line: 216
  Char: 39
  Code: 0
Geoffi
projects/geonetwork
