Hi Andreas,
I was trying to use the h2.db so the default one. The problem was in the jdbc.properties configuration file. It was pointing to a folder not writable by tomcat user.
In the meanwhile, I solved the problem related to the elastic search and I was also able to use the latest version of geonetwork.
Now I can move on trying to solve the problem with the DOI
Thanks
Bartolomeo
Sent: Wednesday, November 24, 2021 16:23
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...>; Juan Luis Rodríguez Ponce <juanluisrp@...444...>
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] errors when opening a fresh installation of Geonetwork
Hi Bartolomeo,
it seems that you have some issues with your database connection. Which database are you using?
Regards
Andreas
Am 04.11.2021 um 11:58 schrieb Ventura Bartolomeo via GeoNetwork-users:
Dear Juan,
Thanks for your reply I installed elastic search and then I tried to run geonetwork using
both the .war file downloaded here
https://sourceforge.net/projects/geonetwork/files/GeoNetwork_opensource/v4.0.5/
and the one obtained using maven but none of them is not working
Please find attached the log file.
Consider that I set 777 as permission in tomcat folder
Bartolomeo
From: Juan Luis Rodríguez Ponce <juanluisrp@...444...><mailto:juanluisrp@…444…>
Sent: Wednesday, November 3, 2021 17:01
To: Ventura Bartolomeo <bartolomeo.ventura@...1518...><mailto:bartolomeo.ventura@…1518…>
Cc: geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net>
Hello Ventura,
On Wed, Nov 3, 2021 at 3:42 PM Ventura Bartolomeo via GeoNetwork-users <geonetwork-users@lists.sourceforge.net<mailto:geonetwork-users@lists.sourceforge.net><mailto:geonetwork-users@lists.sourceforge.net><mailto:geonetwork-users@lists.sourceforge.net>> wrote:
I have just installed the latest version of Geonetwork but as soon as I open the web page I got these two errors in two pink boxes
* Query returned an invalid response. Check the console for details.
* Unable to revive connection to http://localhost:9200. Error is Connection refused
Every time I moved through the different menu I got these errors
I deployed .war file running the following command
cd web; mvn -Djetty.port=9090 jetty:run
It looks like you are trying to run GeoNetwork 4. Could it be? In that case you will need an Elasticsearch instance to act as index. Take a look at the v4 docks [1].
Juan Luis.
[1] https://www.geonetwork-opensource.org/manuals/4.0.x/en/overview/change-log/version-4.0.0.html
Vriendelijke groeten / Kind regards,
Juan Luis Rodríguez.
[Image removed by sender.]<http://www.geocat.net/><http://www.geocat.net/>
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664<tel:+31318416664><tel:+31318416664>
Please consider the environment before printing this email.
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
Andreas Böhme
Techniker/Technician
Landschaftsökologie/Computational Landscape Ecology
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Helmholtz Centre for Environmental Research GmbH - UFZ
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 1058
andreas.boehme@...181...<mailto:andreas.boehme@…181…>, www.ufz.de<http://www.ufz.de>
Sitz der Gesellschaft/Registered Office: Leipzig
Registergericht/Registration Office: Amtsgericht Leipzig
Handelsregister Nr./Trade Register Nr.: B 4703
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: N.N.
Wissenschaftlicher Geschäftsführer/Scientific Managing Director:
Prof. Dr. Georg Teutsch
Administrative Geschäftsführerin/Administrative Managing Director:
Dr. Sabine König
Vermeiden Sie unnötige Ausdrucke./Think before printing.
Informationen aus der Wissenschaft (z.B. Veranstaltungshinweise, Projektangaben, Publikationen,
Bücher)
