Hi!
I am trying to connect to the MckoiDB via druid as explaned here:
http://geonetwork-opensource.org/administrator/druid_dbms
Everything works fine until I am trying to connect to the DB.
I get:
Connecting...
Raised SQL Exception:
Message: User Authentication failed.
Code : 0
State : null
Stack is:
com.mckoi.database.jdbc.SQLLoginException: User Authentication failed.
at
com.mckoi.database.jdbc.RemoteDatabaseInterface.login(RemoteDatabaseInterface.java:170)
and so on
I am using geonetwork_desktop v 2.0.2. I did a fresh installation to
rule out any kind of typos in the admin registration process. In
GeoNetwork logging in as admin works as it should. Does anyone know what
the problem might be?
Best regards
Kai
