[GeoNetwork-users] FileAppender instead of ConsoleAppender in catalina.out file
Hi All,
Sorry for cross posting.
I now seem to GN version 2.7 snapshot revision r8695 with ANZMEST
schemaplugins revision r8650.p migrated and running on the new server.
I am now debugging or documenting the errors.
When I start up GN I get the following in the catalina.out file:
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Is this a bug or is it something that I have to set in some
configuration file?
Thanks.
John Hockaday
