[GeoNetwork-users-fr] [GN 3.0] Page blanche pour se connecter à l'interface d'admin
Bonjour,
Nous essayons de déployer un Geonetwork 3.0.3 à des fins de tests sur la configuration suivante :
Tomcat 8
Java 1.8
Machine Debian
La page de connexion à l'interface d'admin apparaît blanche :
http://dgiwg.ign.fr:8081/geonetwork/srv/fre/catalog.signin
et les erreurs JS suivantes sont constatées :
SyntaxError: expected expression, got '<'
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
gn_login.js (ligne 1)
Error: [$injector:modulerr] http://errors.angularjs.org/1.3.4/$injector/modulerr?p0=gn_login&p1=[%24injector%3Anomod]%20http%3A%2F%2Ferrors.angularjs.org%2F1.3.4%2F%24injector%2Fnomod%3Fp0%3Dgn_login z%2F<%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A343%3A409 Ld%2F<%2F<%2F<%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A358%3A366 a%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A358%3A7 Ld%2F<%2F<%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A358%3A1 g%2F<%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A372%3A149 r%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A344%3A294 g%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A371%3A1 Kb%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A375%3A187 rc%2Fd%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A354%3A387 rc%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A355%3A179 Gd%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A354%3A1 %40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A586%3A328 d.Callbacks%2Fq%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A78%3A455 d.Callbacks%2Fn.fireWith%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A80%3A257 .ready%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A35%3A210 ma%40http%3A%2F%2Fdgiwg.ign.fr%3A8081%2Fgeonetwork%2Fstatic%2Flib.js%3A30%3A397
lib.js (ligne 343, col. 408)
Effectivement le fichier http://dgiwg.ign.fr:8081/geonetwork/static/gn_login.js est bizarre...
Rien de spécial dans les logs geonetwork a priori.
Une idée d'où ça peut venir ?
Merci d'avance
[Description : IGN-RVB.wmf]
Marie Lambois
_______________________________________________________________
Normalisation | Service des Services et des Applications Innovantes
Direction des SerVICEs et dU système d'information
T + 33(0)1 43 98 80 00 poste 7162 P + 33(0)6 72 96 12 79
73, AVENUE DE PARIS, 94165 saint mande cedex
ign.fr - geoportail.gouv.fr
(attachments)
Avez-vous bien remis les droits du répertoire de la webapp au user tomcat ?
sudo chown -R tomcat8:tomcat8 .../tomcat/webapps/geonetwork
-----Message d'origine-----
De : Marie Lambois [mailto:Marie.Lambois@anonymised.com]
Envoyé : jeudi 5 novembre 2015 09:55
À : geonetwork-users-fr@lists.sourceforge.net
Cc : Clement Drouadaine
Objet : [GeoNetwork-users-fr] [GN 3.0] Page blanche pour se connecter à l'interface d'admin
Bonjour,
Tomcat 8
Java 1.8
Machine Debian
Merci d'avance
Marie Lambois
Normalisation | Service des Services et des Applications Innovantes Direction des SerVICEs et dU système d'information
73, AVENUE DE PARIS, 94165 saint mande cedex ign.fr - geoportail.gouv.fr
Oui tout le répertoire /opt/tomcat8 est au user tomcat.
Par contre quand je relance tomcat en tant que user tomcat, ça échoue car il n'arrive pas à écrire geonetwork.lock.db. Où est-ce qu'il est sensé l'écrire c'est dans un autre répertoire ?
Du coup pour l'instant tout est lancé en root.
Marie
De : REBOUX Maël [mailto:m.reboux@anonymised.com]
Envoyé : vendredi 6 novembre 2015 09:24
À : Marie Lambois; geonetwork-users-fr@lists.sourceforge.net
Objet : RE: [GN 3.0] Page blanche pour se connecter à l'interface d'admin
De : Marie Lambois [mailto:Marie.Lambois@anonymised.com] Envoyé : jeudi 5 novembre 2015 09:55 À : geonetwork-users-fr@lists.sourceforge.net
Bonjour,
Tomcat 8
Java 1.8
Machine Debian
Merci d'avance
Marie Lambois
Extrait de mon guide d'install :
On est au stade où on vient de déployer un WAR, premier démarrage.
/!\ les fichiers de la base de données sont créés directement sous /var/lib/tomcat/. Bien remettre les droits de ce répertoire à Tomcat en cas d'erreurs répétées dans les logs lors d'une fresh install.
De mémoire le fichier se nomme /var/lib/tomcat/geonetwork.db
Donc : pb de droits.
Je ne peux pas t'en dire plus : je suis sous Tomcat7.
Envoyé : vendredi 6 novembre 2015 18:42
À : REBOUX Maël; geonetwork-users-fr@lists.sourceforge.net
Marie
Bonjour,
Tomcat 8
Java 1.8
Machine Debian
Merci d'avance
Marie Lambois
