Hi Armin,
Thanks for the information. I’ll try your methods out and let you know if I am successful or not.
Thanks again,
Jerry
From: armin11 [via OSGeo.org] [mailto:ml-node+s1560n5013959h80@anonymised.com]
Sent: Monday, November 05, 2012 4:05 AM
To: Mount, Jerry
Subject: Re: geonetwork 2.6.4 command line linstallation inux
Hello,
here is a little doc for the installation of geonetwork 2.6.4 and
geoserver 2.2 on debian squeeze. Hope it will help, if you have further
questions don't hesitate to ask:
http://www.geoportal.rlp.de/mediawiki/index.php/Installation_geonetwork_/_geoserver_Debian_squeeze
Regards
Armin
On 05.11.2012 08:21, Armin Retterath wrote:
Hello,
I did something similar last week, gn 2.6.4, geoserver 2.2 on a debian
squeeze. It will be good to use different containers for both software.
I prefered to run gn in the tomcat6 (from squeeze) and geoserver with
the integrated jetty. They run on different ports (8080 - tomcat6, 8180
- jetty). The geoserver is started by a start/stop script
(/etc/init.d/geoserver) I use the apache2 http proxy engine to serve the
different ports outside on port 80. It should not be so difficult. If
you need further information, please ask.
Regards
Armin
On 05.11.2012 03:31, jmount wrote:
I am looking for detailed instructions on installing Geonetwork 2.6.4 (or
newer) on a hosted Linux machine. Tomcat is installed already and
automatically deploys java applications - I tested with the War file but I
want to install Geoserver and everything else too. I have a shared Tomcat
currently but will be upgrading to a private Tomcat so that I run jar files
directly too. I have to install through ssh without a GUI. I've set up
Geonetwork on Windows machine that I could directly control but haven't
installed on a Linux machine that I don't have root access.
A couple of questions:
1) is there an example install.xml file that I can use to tailor to my
installation - the documentation seems to suggest that I generate the
automated install xml file using the installer GUI but I can't run that in
my environment.
2) has anyone set up this successfully in a similar environment?
3) are there any detailed installation examples available?
Thanks for any information,
Sincerely,
Jerry
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-2-6-4-command-line-linstallation-inux-tp5013909.html
LogMeIn Central: Instant, anywhere, Remote PC access and management.
Stay in control, update software, and manage PCs from one command center
Diagnose problems and improve visibility into emerging IT issues
Automate, monitor and manage. Do more in less time with Central
http://p.sf.net/sfu/logmein12331_d2d
GeoNetwork-users mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5013959&i=0>
Zentrale Stelle Geodateninfrastruktur
Rheinland-Pfalz
LVermGeo-RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
0261/492-466
[hidden email]</user/SendEmail.jtp?type=node&node=5013959&i=1>
[hidden email]</user/SendEmail.jtp?type=node&node=5013959&i=2>
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/geonetwork-2-6-4-command-line-linstallation-inux-tp5013909p5013959.html
To unsubscribe from geonetwork 2.6.4 command line linstallation inux, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5013909&code=amVycnktbW91bnRAdWlvd2EuZWR1fDUwMTM5MDl8OTA4NDIyNjYx>\.
NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html!nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers!nabble%3Aemail.naml-instant_emails!nabble%3Aemail.naml-send_instant_email!nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/geonetwork-2-6-4-command-line-linstallation-inux-tp5013909p5013991.html
