[GeoNetwork-users] geonetwork 2.6.4 - harvesting - "java.net.ConnectException; Connection timed out"
Hi all !
We are runnig a geonetwork 2.6.4 - instance. When it is harvested (CSW,
from our test-environement within our own LAN) this always ends up in in
an "java.net.ConnectException; Connection timed out".
A "GetCapabilities" or "GetRecords" - Request works fine.
The logfile entries are listed below.
Any hints for solving this would be appreciated,
Christian
The server beiing harvested says:
    </ogc:Id_Capabilities>^M
  </ogc:Filter_Capabilities>^M
</csw:Capabilities>
2012-04-27 14:57:12,603 INFO [jeeves.service] - -> output ended for
: csw
2012-04-27 14:57:12,603 INFO [jeeves.service] - -> dispatch ended for
: csw
The harvesting test-server says :
</node>
2012-04-27 14:57:00,571 INFO [jeeves.service] - -> output ended for
: xml.harvesting.get
2012-04-27 14:57:00,572 INFO [jeeves.service] - -> dispatch ended for
2012-04-27 14:57:12,335 INFO [jeeves.request] -
2012-04-27 14:57:12,336 INFO [jeeves.request] - HTML Request (from
10.152.21.72) : /geonetwork/srv/en/xml.harvesting.run
2012-04-27 14:57:12,336 DEBUG [jeeves.request] - Method : POST
2012-04-27 14:57:12,336 DEBUG [jeeves.request] - Content type :
application/xml; charset=UTF-8
2012-04-27 14:57:12,336 DEBUG [jeeves.request] - Accept :
text/javascript, text/html, application/xml, text/xml, */*
2012-04-27 14:57:12,336 DEBUG [jeeves.request] - Session id is
32E12033FF9B2C925BF8D06B8B129D0F
2012-04-27 14:57:12,339 INFO [jeeves.service] - Dispatching :
xml.harvesting.run
2012-04-27 14:57:12,339 DEBUG [jeeves.service] - -> parameters are :
<request>
  <id>1001</id>
</request>
2012-04-27 14:57:12,339 ERROR [jeeves.dbmspool] - reconnecting:
126509>=1 ms since last connection
2012-04-27 14:57:12,419 DEBUG [jeeves.resources] - ORACLE is using
TRANSACTION_READ_COMMITTED
2012-04-27 14:57:12,420 ERROR [jeeves.dbmspool] - reconnecting:
126514>=1 ms since last connection
2012-04-27 14:57:12,421 INFO [jeeves.service] - -> dispatching to
output for : xml.harvesting.run
2012-04-27 14:57:12,421 INFO [jeeves.service] - -> writing xml for
2012-04-27 14:57:12,421 DEBUG [jeeves.service] - Service xml is :
<response>
  <id status="ok">1001</id>
</response>
2012-04-27 14:57:12,422 INFO [jeeves.service] - -> output ended for
2012-04-27 14:57:12,422 INFO [jeeves.service] - -> dispatch ended for
2012-04-27 14:57:12,494 DEBUG [jeeves.resources] - ORACLE is using
2012-04-27 14:57:33,645 WARN [geonetwork.harvester] - Raised exception
when searching : java.net.ConnectException: Connection timed
out
2012-04-27 14:57:33,646 WARN [geonetwork.harvester] - Raised exception
while harvesting from : TESTINSTANZ (CswHarvester)
2012-04-27 14:57:33,646 WARN [geonetwork.harvester] - (C) Class :
OperationAbortedEx
2012-04-27 14:57:33,646 WARN [geonetwork.harvester] - (C) Message :
Raised exception when searching
