Hi
I try to install GeoNetwork 3 from war file via Tomcat Menager.
After Deploy GeoNetwork don't start. I have running status = false.
When i install older version all works ok.
Hi
this is error log from catalina....
INFO: Undeploying context [/geonetwork]
Apr 30, 2015 3:10:04 PM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive /var/lib/tomcat7/webapps/geonetwork.war
Apr 30, 2015 3:10:05 PM org.apache.catalina.loader.WebappClassLoader
validateJarFile
INFO: validateJarFile(/var/lib/tomcat7/webapps/geonetwork/WEB-INF/lib/javax.servlet-3.0.0.v201112011016.jar)
- jar not loaded. See Servlet Spec 3.0, section 10.7.2. Offending
class: javax/servlet/Servlet.class
Apr 30, 2015 3:10:15 PM org.apache.catalina.core.StandardContext startInternal
SEVERE: Error listenerStart
SEVERE: Context [/geonetwork] startup failed due to previous errors
Apr 30, 2015 3:10:15 PM org.apache.catalina.loader.WebappClassLoader
clearReferencesJdbc
SEVERE: The web application [/geonetwork] registered the JDBC driver
[org.postgresql.Driver] but failed to unregister it when the web
application was stopped. To prevent a memory leak, the JDBC Driver has
been forcibly unregistered.
clearReferencesJdbc
[org.h2.Driver] but failed to unregister it when the web application
was stopped. To prevent a memory leak, the JDBC Driver has been
clearReferencesThreads
SEVERE: The web application [/geonetwork] appears to have started a
thread named [Timer-4] but has failed to stop it. This is very likely
to create a memory leak.
thread named [ElementEventQueue.QProcessor-1] but has failed to stop
it. This is very likely to create a memory leak.
2015-04-30 14:48 GMT+02:00 konto gmail <specjal@anonymised.com>:
Hi
anybody?
2015-04-30 15:16 GMT+02:00 konto gmail <specjal@anonymised.com>:
validateJarFile
clearReferencesJdbc
clearReferencesJdbc
it. This is very likely to create a memory leak.2015-04-30 14:48 GMT+02:00 konto gmail <specjal@anonymised.com>:
Hi
I have kind of the same situation here. Version 2.10.4 works without issues,
whereas for gn3 the error log is very similar to what /specjal/ posted
above.
A question might be relevant here. Did you try to do a fresh reinstall and
reconfiguration of tomcat?
In my case the answer is no, because I don't want to spoil currently working
gn instance. Which brings in question if and how both instances, gn2 and gn3
could be ran simultaneously under the same tomcat server. (also invoked in
this post
http://osgeo-org.1560.x6.nabble.com/Migrate-Geonetwork-2-10-4-to-3-0-0-beta-tp5202539p5206960.html)
This is the system configuration:
Ubuntu 14.04 LTS
Java 1.7.0_65
Apache Tomcat 6
Apache Server 2.4.7
GeoNetwork 2.10.4 with a native h2 db
I guess there must be some kind of mismatch with the tomcat configuration
adapted for gn2, because the gn3 structure has changed. Well, the developers
would know where the changes took place. In the meanwhile I can continue
browsing error logs like a blind chicken and keep hoping that one of the
trial and error exercises will be successful.
Maybe it's only a matter of how to correctly point to the database?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoNetwork-3-0-install-error-from-war-file-tp5203645p5207179.html
Hi
2015-05-22 17:20 GMT+02:00 zer0mode <otoncopi@anonymised.com>:
issues,
above.A question might be relevant here. Did you try to do a fresh reinstall and
working
gn3
this posthttp://osgeo-org.1560.x6.nabble.com/Migrate-Geonetwork-2-10-4-to-3-0-0-beta-tp5202539p5206960.html
)This is the system configuration:
Ubuntu 14.04 LTS
Java 1.7.0_65
Apache Tomcat 6
See
http://osgeo-org.1560.x6.nabble.com/Tomcat-version-with-GN3-td5206376.html
Tomcat 6 is probably (?) the problem. AFAIK, GN3 has been tested on jetty
8x+, Tomcat7+. There is some issues on JBoss.
HTH.
Francois
Apache Server 2.4.7
GeoNetwork 2.10.4 with a native h2 dbI guess there must be some kind of mismatch with the tomcat configuration
developers
trial and error exercises will be successful.Maybe it's only a matter of how to correctly point to the database?
Sent from the GeoNetwork users mailing list archive at Nabble.com.------------------------------------------------------------------------------
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
GeoNetwork-users mailing list
You should watch the logs to know a bit more about what's going wrong.
On Fri, May 22, 2015 at 5:38 PM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:
Hi
> Hi,
> issues,
> above.
and
> working
> gn3
in
> this post
> Ubuntu 14.04 LTS
> Java 1.7.0_65
> Apache Tomcat 6
>See
8x+, Tomcat7+. There is some issues on JBoss.HTH.
Francois
> Apache Server 2.4.7
> developers
> Application Monitoring Software and Tool - ManageEngine Applications Manager
> geonetwork-users List Signup and Options
> GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Florent Gravin
Camptocamp - Chambéry
0479444492
