If you have any improvements you want to contribute back, the best is to use git to get a local copy of the source code, apply the fix and put out a Pull request so your improvements can be integrated quickly. Otherwise you can also create new Tickets in the issue tracker: https://github.com/geonetwork/core-geonetwork/issues
Thanks and congratulations to all the community members and developers that have been putting effort and energy in these releases and the documentation update https://docs.geonetwork-opensource.org/
can also create new Tickets in the issue tracker: Issues · geonetwork/core-geonetwork · GitHub
