[GeoNetwork-users] GeoNetwork 4.0.3 - Error importing templates
Good morning.
We have been using GeoNetwork 4.0.0, but we were advised to update it to the 4.0.3 version.
Due to the fact that our previous installation was in the stage of testing, we decided to delete everything (GoeNetwork, Elasticsearch, the database....) and install everything with the new version. The database we are using is an Oracle instance.
After installing everything we got an ORA-00942 about missing tables. After checking the migration scripts, we have discovered that the missing tables are METADATASTATUS and METADATAIDENTIFIERTEMPLATE. They were part of the 4.0.0 version, but in the last version those tables are missing. After creating those tables in the database, the error is gone.
But further testing has risen an even more troubling error: we can't load any metadata template. The templates are loaded without any problem with the default database (H2), but once we change it to the Oracle instance we get the error. We are not sure if it is related with the missing tables or if it's something else, but we are stuck.
Does anyone know what could be the issue?
This is the error from the log:
* {"message":"Error loading 'iso19139' template file 'C:\\Tomcat9e\\webapps\\GeoNetwork-4.0.3-0\\WEB-INF\\data\\config\\schema_plugins\\iso19139\\templates\\deegree_fragment_tester.xml'. Error is Error detecting if metadata is draft.","uuid":null,"draft":false,"approved":false,"date":"2021-04-13T13:57:19.978Z","stack":"java.lang.Exception: Error loading 'iso19139' template file 'C:\\Tomcat9e\\webapps\\GeoNetwork-4.0.3-0\\WEB-INF\\data\\config\\schema_plugins\\iso19139\\templates\\deegree_fragment_tester.xml'. Error is Error detecting if metadata is draft.\r\n\tat org.fao.geonet.api.records.MetadataSampleApi.addTemplates(MetadataSampleApi.java:304)\r\n\tat org.fao.geonet.api.records.MetadataSampleApi$$FastClassBySpringCGLIB$$f9c6aa3.invoke(<generated>)\r\n\tat org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218)\r\n\tat org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:771)\r\n\tat org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)\r\n\tat org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.proceed(CglibAopProxy.java:749)\r\n\tat org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:69)\r\n\tat org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)\r\n\tat org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.proceed(CglibAopProxy.java:749)\r\n\tat org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:691)\r\n\tat org.fao.geonet.api.records.MetadataSampleApi$$EnhancerBySpringCGLIB$$4582b81f.addTemplates(<generated>)\r\n\tat sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)\r\n\tat sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)\r\n\tat sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)\r\n\tat java.lang.reflect.Method.invoke(Method.java:498)\r\n\tat org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:190)\r\n\tat org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:138)\r\n\tat org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105)\r\n\tat org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:879)\r\n\tat org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:793)\r\n\tat org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)\r\n\tat org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet.access$101(JeevesDispatcherServlet.java:44)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:56)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:52)\r\n\tat jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:73)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:49)\r\n\tat org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)\r\n\tat org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)\r\n\tat org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:920)\r\n\tat javax.servlet.http.HttpServlet.service(HttpServlet.java:655)\r\n\tat org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)\r\n\tat javax.servlet.http.HttpServlet.service(HttpServlet.java:733)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.web.CORSResponseFilter.doFilter(CORSResponseFilter.java:129)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:121)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:58)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.web.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:110)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)\r\n\tat org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)\r\n\tat org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)\r\n\tat org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.geonetwork.http.SessionTimeoutCookieFilter.doFilter(SessionTimeoutCookieFilter.java:91)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)\r\n\tat org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)\r\n\tat org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:118)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:155)\r\n\tat org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:50)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:141)\r\n\tat org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)\r\n\tat org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)\r\n\tat org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)\r\n\tat org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)\r\n\tat jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:104)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)\r\n\tat org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)\r\n\tat org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)\r\n\tat org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:542)\r\n\tat org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)\r\n\tat org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)\r\n\tat org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)\r\n\tat org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)\r\n\tat org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)\r\n\tat org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:374)\r\n\tat org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)\r\n\tat org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)\r\n\tat org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1590)\r\n\tat org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)\r\n\tat java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)\r\n\tat java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)\r\n\tat org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)\r\n\tat java.lang.Thread.run(Thread.java:748)\r\n"}
Best regards.
?scar Diago Alonso
Analista / Desarrollador GIS
oscar.diago@anonymised.com
Tfno.: +34 945 13 13 72
C/ Pintor Clemente Arr?iz, 3 BJ (01008) Vitoria-Gasteiz, ?lava
[https://www.geograma.com/pie-de-mail/geogramatalks.png\]<https://forms.office.com/Pages/ResponsePage.aspx?id=wPPADQuLC0G543HQYdWDeq6a3Ssg6OBOrhrl-IvylrBUMVVNWkI2N0dGQk04RkZTUVpLRTlTSzFYMi4u&gt;
Si no ves la imagen puedes acceder al bolet?n de Geograma desde aqu?.<https://forms.office.com/Pages/ResponsePage.aspx?id=wPPADQuLC0G543HQYdWDeq6a3Ssg6OBOrhrl-IvylrBUMVVNWkI2N0dGQk04RkZTUVpLRTlTSzFYMi4u&gt;
Tratamos su direcci?n de correo electr?nico y otros datos personales para mantener el contacto y comunicaci?n con Ud. y, en su caso, remitirle informaci?n sobre nuestros productos y servicios. Si no desea recibir tal informaci?n env?e un e-mail en tal sentido a dpd@anonymised.com Puede acceder, rectificar y suprimir los datos, as? como otros derechos, como se detalla en la informaci?n adicional y completa a su disposici?n en nuestra pol?tica de privacidad en la URL bit.ly/geo-privacidad. Este mensaje y los archivos adjuntos al mismo son privados y confidenciales, si no es Ud. el destinatario y ha recibido este mensaje por error, rogamos nos lo comunique inmediatamente sin difundir, almacenar o copiar su contenido.
[https://www.geograma.com/pie-de-mail/geo-linkedin.png\]<https://bit.ly/geo-linkedin&gt; [https://www.geograma.com/pie-de-mail/geo-twitter.png\] <https://bit.ly/geo-tw&gt;
Hi Oscar
Have you checked during the startup with an empty Oracle database if any
errors logged related to the database setup? I tested with H2 and no issues
(as you already indicated), will check to test also with Postgres, to
confirm if there can be some specific issue related to Oracle.
Jose García
On Wed, Apr 14, 2021 at 5:12 PM Oscar Diago Alonso <Oscar.Diago@anonymised.com>
wrote:
Good morning.
the 4.0.3 version.
Best regards.
?scar Diago Alonso
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Hi.
Thanks for the answer! No, we haven’t detected any problem related to the database, except the missing tables I have mentioned in my previous message.
If the developer team would like to test it with an Oracle database, there are free virtual machines for development purposes: https://www.oracle.com/downloads/developer-vm/community-downloads.html
We have gone back to the 4.0.0 version of GeoNetwork, that is working fine against Oracle (after changing some LONG fields into CLOB). We wanted to update it because we have been told newer versions work better with multilingual metadata.
Best regards.
De: Jose Garcia <jose.garcia@...444...>
Enviado el: jueves, 15 de abril de 2021 8:08
Para: Oscar Diago Alonso <Oscar.Diago@...1602...>
CC: geonetwork-users@lists.sourceforge.net
Asunto: Re: [GeoNetwork-users] GeoNetwork 4.0.3 - Error importing templates
Hi Oscar
Have you checked during the startup with an empty Oracle database if any errors logged related to the database setup? I tested with H2 and no issues (as you already indicated), will check to test also with Postgres, to confirm if there can be some specific issue related to Oracle.
Jose García
On Wed, Apr 14, 2021 at 5:12 PM Oscar Diago Alonso <Oscar.Diago@...1602...<mailto:Oscar.Diago@…1602…>> wrote:
Good morning.
* {"message":"Error loading 'iso19139' template file 'C:\\Tomcat9e\\webapps\\GeoNetwork-4.0.3-0\\WEB-INF\\data\\config\\schema_plugins\\iso19139\\templates\\deegree_fragment_tester.xml'. Error is Error detecting if metadata is draft.","uuid":null,"draft":false,"approved":false,"date":"2021-04-13T13:57:19.978Z","stack":"java.lang.Exception: Error loading 'iso19139' template file 'C:\\Tomcat9e\\webapps\\GeoNetwork-4.0.3-0\\WEB-INF\\data\\config\\schema_plugins\\iso19139\\templates\\deegree_fragment_tester.xml'. Error is Error detecting if metadata is draft.\r\n\tat org.fao.geonet.api.records.MetadataSampleApi.addTemplates(MetadataSampleApi.java:304)\r\n\tat org.fao.geonet.api.records.MetadataSampleApi$$FastClassBySpringCGLIB$$f9c6aa3.invoke(<generated>)\r\n\tat org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:218)\r\n\tat org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.invokeJoinpoint(CglibAopProxy.java:771)\r\n\tat org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)\r\n\tat org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.proceed(CglibAopProxy.java:749)\r\n\tat org.springframework.security.access.intercept.aopalliance.MethodSecurityInterceptor.invoke(MethodSecurityInterceptor.java:69)\r\n\tat org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)\r\n\tat org.springframework.aop.framework.CglibAopProxy$CglibMethodInvocation.proceed(CglibAopProxy.java:749)\r\n\tat org.springframework.aop.framework.CglibAopProxy$DynamicAdvisedInterceptor.intercept(CglibAopProxy.java:691)\r\n\tat org.fao.geonet.api.records.MetadataSampleApi$$EnhancerBySpringCGLIB$$4582b81f.addTemplates(<generated>)\r\n\tat sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)\r\n\tat sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)\r\n\tat sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)\r\n\tat java.lang.reflect.Method.invoke(Method.java:498)\r\n\tat org.springframework.web.method.support.InvocableHandlerMethod.doInvoke(InvocableHandlerMethod.java:190)\r\n\tat org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:138)\r\n\tat org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:105)\r\n\tat org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:879)\r\n\tat org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:793)\r\n\tat org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:87)\r\n\tat org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1040)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet.access$101(JeevesDispatcherServlet.java:44)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:56)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet$1.doInTransaction(JeevesDispatcherServlet.java:52)\r\n\tat jeeves.transaction.TransactionManager.runInTransaction(TransactionManager.java:73)\r\n\tat jeeves.config.springutil.JeevesDispatcherServlet.doDispatch(JeevesDispatcherServlet.java:49)\r\n\tat org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:943)\r\n\tat org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)\r\n\tat org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:920)\r\n\tat javax.servlet.http.HttpServlet.service(HttpServlet.java:655)\r\n\tat org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)\r\n\tat javax.servlet.http.HttpServlet.service(HttpServlet.java:733)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.web.CORSResponseFilter.doFilter(CORSResponseFilter.java:129)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.monitor.webapp.WebappMetricsFilter.doFilter(WebappMetricsFilter.java:121)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.monitor.webapp.MetricsRegistryInitializerFilter.doFilter(MetricsRegistryInitializerFilter.java:58)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.fao.geonet.web.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:110)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176)\r\n\tat org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145)\r\n\tat org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92)\r\n\tat org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.geonetwork.http.SessionTimeoutCookieFilter.doFilter(SessionTimeoutCookieFilter.java:91)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:320)\r\n\tat org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)\r\n\tat org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:118)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:155)\r\n\tat org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat jeeves.config.springutil.PassthroughFilter.doFilter(PassthroughFilter.java:50)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:141)\r\n\tat org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)\r\n\tat org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:334)\r\n\tat org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:215)\r\n\tat org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:178)\r\n\tat org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:358)\r\n\tat org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:271)\r\n\tat jeeves.config.springutil.JeevesDelegatingFilterProxy.doFilter(JeevesDelegatingFilterProxy.java:104)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:201)\r\n\tat org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:119)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)\r\n\tat org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)\r\n\tat org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202)\r\n\tat org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)\r\n\tat org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:542)\r\n\tat org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)\r\n\tat org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)\r\n\tat org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:690)\r\n\tat org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)\r\n\tat org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343)\r\n\tat org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:374)\r\n\tat org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)\r\n\tat org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)\r\n\tat org.apache.tomcat.util.net<http://org.apache.tomcat.util.net>.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1590)\r\n\tat org.apache.tomcat.util.net<http://org.apache.tomcat.util.net>.SocketProcessorBase.run(SocketProcessorBase.java:49)\r\n\tat java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)\r\n\tat java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)\r\n\tat org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)\r\n\tat java.lang.Thread.run(Thread.java:748)\r\n"}
Best regards.
?scar Diago Alonso
oscar.diago@...1602...<mailto:oscar.diago@…1602…>
Tratamos su direcci?n de correo electr?nico y otros datos personales para mantener el contacto y comunicaci?n con Ud. y, en su caso, remitirle informaci?n sobre nuestros productos y servicios. Si no desea recibir tal informaci?n env?e un e-mail en tal sentido a dpd@...1602...<mailto:dpd@…1602…>. Puede acceder, rectificar y suprimir los datos, as? como otros derechos, como se detalla en la informaci?n adicional y completa a su disposici?n en nuestra pol?tica de privacidad en la URL bit.ly/geo-privacidad<http://bit.ly/geo-privacidad&gt;\. Este mensaje y los archivos adjuntos al mismo son privados y confidenciales, si no es Ud. el destinatario y ha recibido este mensaje por error, rogamos nos lo comunique inmediatamente sin difundir, almacenar o copiar su contenido.
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
Jose García
[https://www.geocat.net/wp-content/uploads/2015/07/GeoCat_small1.png\]<http://www.geocat.net/&gt;
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664<tel:+31318416664>
Please consider the environment before printing this email.
If table are missing on startup, you should try to enable log to DEBUG and
check any SQL errors
https://github.com/geonetwork/core-geonetwork/blob/main/web/src/main/webapp/WEB-INF/classes/log4j.xml#L224-L238
Also the exception you get sounds related to Draft mode "Error is Error
detecting if metadata is draft"
You could also try to comment on Draft beans and use the Base ones ? it may
gives more ideas on how to fix the issue...
https://github.com/geonetwork/core-geonetwork/blob/main/web/src/main/webResources/WEB-INF/config-spring-geonetwork.xml#L165-L175
Cheers.
Francois
Le jeu. 22 avr. 2021 à 11:22, Oscar Diago Alonso <Oscar.Diago@anonymised.com..>
a écrit :
Hi.
Best regards.
De: Jose Garcia <jose.garcia@anonymised.com>
Para: Oscar Diago Alonso <Oscar.Diago@anonymised.com>
Hi Oscar
Jose García
Oscar.Diago@anonymised.com<mailto:Oscar.Diago@anonymised.com>> wrote:
Good morning.
the 4.0.3 version.
Best regards.
?scar Diago Alonso
oscar.diago@anonymised.com<mailto:oscar.diago@anonymised.com>
informaci?n env?e un e-mail en tal sentido a dpd@anonymised.com<mailto:
dpd@anonymised.com>. Puede acceder, rectificar y suprimir los datos, as?
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
